Question about Yamaha RX-V375
Receiver shuts off during sound test - Yamaha RX-V375
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
No sound from center speaker or subwoofer on HT-R500 av receiver
Take a left or right speaker that you know works and connect it to the center and test. Repeat for the sub.
Are you sure you setup the AVR correctly that it knows you have a center and sub?
Aug 16, 2014 | Audio Players & Recorders
No sound from tv to speakers
i assume you are hooking up from tv to receiver with an optical cable? Check the settings on your tv. Most tv's have a setting to turn on/off the optical audio output
Apr 21, 2014 | Harmon Kardon Harman Kardon Avr-20 Ii...
There is no sound coming out of the subwoofer
I assume it's an active subwoofer, since it hums. Did you activate sub in the receiver menu? Did you turn up the volume on the sub?
Jul 08, 2010 | Yamaha HTR-5840 Receiver
CENTER CHANNEL NOT FUNCTIONING
Separate wires better trim them shorter to put into the panel they may be touching and shorting out when the test sends signal to that wire, thats why the breaker is tripping to protect the unit.
Nov 29, 2009 | Audio Players & Recorders
No sound from rear speakers during test tone usng Sony STR-DE475
I had this problem last night.
To solve it, you can reset the amp by:
1) Put the receiver on stand-by
2) Hold down "MODE" button and press on button
3) "S.F. CLR" appears in the display and surround is back on.
Good luck
Dr Gardner
Jan 21, 2009 | Sony STR-DE475 Receiver
Clicking noise from Onkyo TX-SR606 during television broadcast
I seem to recall a sub-menu setting having to do with "auto shut off" or something like that.
My receiver is packed up, ready to take to Fry's, or I would find that submenu for you.
Jan 04, 2009 | Onkyo TX-SR606 Receiver
All speakers are connected, but center 1 and 2 rears are not working.
Front and center speakers connected correctly and test sound works fine. Center speaker icon does not show on front panel of receiver (except during test) and i get no sound.
Nov 05, 2008 | Yamaha HTR-5840 Receiver
Denon receiver follow up
A sound spike should not heat up the unit enough to shut it down. There is another problem. What is the time frame for the shutdown? Is it only after the unit has been running for a while?
Dan
Apr 05, 2008 | Denon AVR-3805 Receiver
Yamaha RX-V375 Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
