Question about Smeg A1A.1 Gas Kitchen Range
Smeg igniter doesnt work
Igniter doesn't work
Smeg mod nu.sar93xlpg gas cooktop is 20 years old and in good condition The gas igniter recently has been sparking once every 5 mins. works fine except one spark every 5 minutes,any ideas
probably find that after so long the igniter is starting to fail
call smeg and see if there is a replacement one available
there may be after market units from your local gas shop
Jun 25, 2016 | Smeg Cooktops
Smeg SD012 top oven failed
Is the clock set to auto and not manual? Is the clock display flashing? If so then set to manual, this should do the trick
Jan 17, 2014 | Smeg Ovens
Smeg SE290x-5 oven stopped working
Replace igniter if gas .or if elect replace element
Nov 09, 2011 | Smeg Ovens
One of my igniter in my smeg gas cook top does not spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 30, 2011 | Smeg 23 in. SE64 Gas Cooktop
Our smeg oven has stopped working, we have power and gas but the oven does not work. can anyone advise please
A couple of possibilities; oven thermocouple failure or the igniter is dead. If the latter has failed preventing the initial ignition, the thermocouple will shut down the gas supply quite rapidly.
Aug 08, 2011 | Smeg A1A.1 Gas Kitchen Range
Ignighter is not working on any burners
if if does not light anymore you have a ignition sequence fault could be a faulty switch foe the ignition pcb ht lead or electrodes
Aug 21, 2009 | Smeg HB96CSS Gas Cooktop
Smeg SAR134A/X does not ignite.
give it a while for the switches to dry if it doesnt start working then reply to me most of the time they will start working also check to make sure the breaker didnt trip
Mar 18, 2008 | Smeg 23 in. SE64 Gas Cooktop
Smeg A1A.1 Gas Kitchen Range Logo
18 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
