Question about Peavey XR 1220 Powered Mixer Mixer Powered
Xr1220 no delay in monitors - Peavey XR 1220 Powered Mixer Mixer Powered
On my peavey xr1220, when I turn on the power switch the board does not power up. What could be the problem?
Probably a fuse ? I have been servicing a lot of Peavey equipment lately and they have some poor circuit designs, a lot of internal un accessible fuses, I might be able to get more info ?
Feb 22, 2015 | Peavey XR 1220 Powered Mixer Mixer Powered
I want to record using Tascam with my peavey xr1220 mixer
What Tascam recorder are you using? If you are multitracking you will be unlikely to be able to use this mixer. Otherwise get a phono lead to fit the tape out and suitable connections for the Tascam recorder at the other end. This will allow you to record the main mix but unless you are a solo act or putting everything through the PA this will probably be pretty useless to you.
Jan 07, 2015 | Peavey XR 1220 Powered Mixer Mixer Powered
I use 5 out of 6 aux. for monitor...That leaves only 1 aux. for delay/reverb. is there another way to hook up delay/reverb to mixer?...SR24-4 mackie mixer...
Why are you not using the inserts? Either assign a sub channel to your effects unit or do it at a channel level. In either case using the insert.
Apr 03, 2014 | Mackie Music
It sounds like you're new to 'professional' mixers. You would NEVER normally use an aux for effects. Any effects will normally be inserted in the sound chain using an insert. You have a pair of group inserts if you are wanting to apply an effect to the output (these are after the mix) and would typically be used for master de-essers or possibly compressor limiters or maybe even an equaliser, it would not be sensible to use an effect like a delay/reverb here.
I would have expected you to be using the group outs for the monitor mixes and am not sure what you may be using them for otherwise. If you used these you would free up 4 of the Aux outs for a 'multi channel' reverb/echos which you could take back into other channels and back into the main mix.
What is it you are tyring to achieve?
Apr 03, 2014 | Mackie 2404-VLZ3 Mixer
User manual for DOD DFX9 DIGITAL DELAY GUITAR PEDAL
Can't find a manual but can still explain. Delays, chorus, flangers, and reverbs are all the same effect except the different names of them will allow you different adjustments. Chorus usually has a width control which controls pitch shifting. Flangers and delays will have a feedback control which simply means, how many times you hear the echo. On reverb units, room size means how long of echo(even though it;s short) you want. Delay is the same with much longer echo, feedback is the same as on flangers except the flangers time is very short meaning the effect is at almost the exact time resulting in feedback causing a metalic sound. I probaly just confused you but good digital delays usually have all the features and will usually do all 4 effects depending on how you set them. If you want delay, set width on 0 and adjust time and feedback. For flanging, adjust width and speed and feedback. Chorusing, adjust time, width, and speed. Reverb, adjust time, set width on 0, and feedback. I see it has a level(mixture, how much effect you hear), and a replay(feedback, how many times you hear it), and a delay knob,(how long the echo will be) The range/mode switch allows for settings of diferent time lengths and INF setting allows for infinite repeat. Hope this helps.
Mar 09, 2013 | Applause MAE148 AcoEle Mandolin Natural...
When I arm a track to record in tracktion 3 I get a delay when monitoring playback.
If you monitor the recording there are two delays... one as audio is converted and stored... the next is when it is retrieved and converted back to audio. Usually the recording interfaces have a monitor function that loops the audio back out before the conversion. playing back previously recorded audio of course will have the delay to retrieve and convert back to audio.
Jul 03, 2011 | Mackie Onyx Blackjack 2x2 Recording...
I can't seem to figure out how to record one track over another without a delay problem? I am using the behringer 1202 mixer into my computer. No problem recording but can't do multiple tracks. I'm new...
This is a common problem with digital recording. Simply put, it takes some time to convert analog (audio) to digital and then more time to convert it back. So, your playback track goes through conversion and introduces some delay. You don't hear this because you have no zero reference. Your recorded sound goes through the A/D converter and also incurs some delay. When you play them back together, you hear the difference in time from one track to another. Most pro recording programs have some method to minimize or cancel the delay like slipping the tracks so they all start together. Pro Tools just introduced a version that automatically does this. They have always had what it called "low latency" monitoring which attempts to keep the "shortest" digital/analog path so overdubs are close enough that we don't hear any issues. So, since you talk about the mixer but not the recording program, I can't tell you specifics but I'd look into the recording program for time alignment settings and options. If you have a manual for the recording program, try to look up latency.
Dec 08, 2010 | Behringer Rx 1202fx 12 Channel Line and...
Increase in delay effect during a lead setting.
This may be he characteristic of mixing of the delayed when high distortion is present...
I would go to music store and compare... I tend to think this is the nature of the beast.
If you consider what the waveforms look like with distortion and then add them delayed... they limit out and when added there is a significant difference when adding or mixing waves that are delayed when squared compared to nice sine waves.
May 08, 2010 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Trying to get rid of delay
is it possible to run all the signals through so they all have the delay?
Jan 11, 2009 | Peavey 32fx USB 32 Channel Mixer
Peavey XR 1220 Powered Mixer Mixer Powered Logo
15 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
