Question about Sony PRS-300 eBook Reader
Ebook cannot be transferred because the license has expired
E-book cannot be transferred because the license has expired
Can I transfer information books, photos, etc. from my Kindle Fire to my iPad Pro?
Books that you have purchased can be read on any iPad using the Kindle Reader, which is a free download. The books will synchronize between devices as well (e.g. if you are reading on page 97 on one device, you can pick up on that page on another).
Photos are a different story. I'd recommend you get them into a cloud based service (dropbox, etc.) where you can view them on any device connected to that service including iPads and other ios devices. Or if you get them onto a computer, they can be moved to any ios device from there. Searching for a solution for you may be best bet; here is a start: http://classroom.synonym.com/upload-pictures-kindle-fire-onto-computer-17304.html
Here is one way to move photos from computer to ios: Step 1: Connect your iPhone to computer with its USB cable, and then run iTunes if it doesn't open automatically. Step 2: Click Device tab > Select Photos > Check SyncPhotos > Select where you want to sync photos (iPhoto, Photos or some specific folder) > Click Apply.
Mar 21, 2017 | Tablets & eReaders
Tip
How to remove DRM protection from Kindle eBooks
I like to read books via amazon kindle fire. It's much more convenient than reading traditional books. However, most content downloaded via Amazon kindle are DRM protected and can't be shared or changed to other devices. This requires an eBook DRM removal software to help us.
ePubor Ultimate Converter is the most suitable program if you need to remove DRM protection from Kindle ebooks. Actually, this ePubor DRM ebook converter can also deal with iTunes iBooks, Nook books, sony ebooks etc.
How to remove DRM from Kindle eBooks?
Step 1. Add Kindle ebooks to ebook converter.
Click Add button, then you can select the ebooks you want to convert. Please note that, you have to download the ebooks to your local computer at first, and have a valid license to read it.
Step 2. Select output format
Click "Output" dropdown list, then select the right output format you want. This DRM ebook converter supports a lot of ebook formats as output, like common eBooks: PDF, Mobi, Epub, devices: Apple devices, Amazon devices, Sony devices, Samsung, Nook etc.
Step 3. Start Removing DRM from Kindle eBooks
Click Start button to start removing DRM from Kindle ebooks.
If you lose the metadata of some ebooks, you can also click edit button to modify the metadata for each eBook file and add your own rate and comments.
on Apr 22, 2014 | Amazon Tablets & eReaders
Transfer books from Kindle to iPad
You are able to move the books to computer, and then sync ebooks to iPad with iTunes. When the Kindle users connect their Kindle tablets to computer with the USB cable, their computers will recognize their Kindle tablets as external hard drives. Then the users can copy and paste the ebooks from Kindle to computer easily. After that, the users are able to sync the books from computer to iPad with iTunes.
This is easy to be done. But when users begin to sync their iPad with iTunes, they may come up with the sync problems of iTunes. The problem may come up when users sync ebooks from iTunes to iPad. During the sync, iTunes will erase all the non-purchased items in your iPad mini. If you are new to iOS devices, you will probably lose files during the sync with iTunes, so you'd better close the auto sync and manually sync the ebooks to your iPad mini with iTunes. The following tutorial will be helpful if you aren't sure about how to accomplish the task:
  1. Start iTunes and go to "Edit > Preference > Devices", and check "Prevent iPods, iPhones and iPads from syncing automatically".
  2. Plug iPad into computer via USB cable, and the software will recognize your iPad and display the iPad icon at the upper right corner.
  3. Click the iPad icon and choose "Books" in the summary panel. Choose the books you want to sync to iPad in the list below, and click "Apply" to start.
How to Transfer Ebooks from Kindle to iPad mini
Sep 29, 2015 | Tablets & eReaders
How do i download kids e books to the tablet?
You can put eBooks on the tablet by using the Aldiko eBook app and your PC to put books in the library.
1) Download an ePub file to your computer. Use Google Books or another eBook store to get the file. Check out http://books.google.com
2) To transfer the ePub file, hook up the tablet to the PC.
3) First mount your USB Storage (Internal), from your PC go the removable disk, you should see the ebooks folder, create a sub folder and name it import.
4) Copy your epub file to the import folder.
5) Next turn off USB storage(Internal).
6) Launch Aldiko, click on Menu which should popup a menu with option such as import. Click on import. It will start to scan your sdcard for any epub files.
7) When the import is finished, click on Bookshelf to refresh. For some reason it just doesn't see any epub files from the USB Storage (ie from the MicroSDCard)
Let me know if this helps.
Feb 28, 2011 | Coby Kyros 716829701508 Tablet PC
Is there a way to take the 100 free eBooks that come with the eReader off of the Libre Pro and put on computer? I don't want to loose them, but I want to make room for more ebooks that I will read first. ...
1 The the Libre Pro supports PDF (Adobe Digital Edition DRM/non-DRM), TXT, FB2, EPUB (Adobe Digital Edition DRM/non-DRM), MOBI (non-DRM only), PRC (non-DRM only)and RTF electronic book format.source:http://aluratek.com/libre-ebook-reader-pro-black2 60 Sites to Download Free Kindle Books if you download free kindle Books protected from kindle DRM from Amazon, you can download Ultimate Convert. Ultimate eBook Converter, helps you reading books anywhere, include the best eBook Converter + DRM Removal functions.
Sep 02, 2010 | Aluratek Libre eBook Reader Pro
Libre eBook Reader Pro (White) SD Card Slot (Up to 32GB) MP3 Player: When i download a book that i can read fine in rus...
Unfortunately Aluratek did copy hardware from Ectaco and did not software. It does not have license to support Cyrillic fonts, so can not support Russian, sorry
May 17, 2010 | Aluratek Libre eBook Reader Pro
Sony PRS-300 eBook Reader Logo
21 people viewed this question
Top Sony Tablets & eReaders Experts
Stan Ford
David Payne
David Payne
Are you a Sony Tablet and eReader Expert? Answer questions, earn points and help others
