Question about Vtech LS6204 1.9 GHz 1-Line Cordless Expansion Handset
Registration fails ,i reset and fails again ,,,,modelcs 6409
Got another phone and need to program it so it will work how do I do this
First be sure the handset battery is well charged as a weak
battery will interfere with the registration process.
Then try the following ( 'works for the D1680, D1481, and similar):
( I ) Deregister the handset:
Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say
"System Reset, Deregister Handset"
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..."
( II ) Now, to re-register the handset:
Set the handset into the base cradle and wait,
after ~30 seconds the handset should display
"Handset #" and be good to go...
...or it will display "Registration Failed"
If "...Failed", try from ( I ) again.
Feb 19, 2016 | Uniden DECT 6.0 Cordless Telephone...
Hand set says connecting even before it is reset with new base.
This sounds like a registration problem, each 'old'
handset must be de-registered from its original
base and then registered to the 'new' base.
NOTE: the CS6229 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
( if needed, else skip ahead to ( III ). )
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
Jul 23, 2015 | Vtech Lands Phones
How to fix nokia n73 sim card registration failed
this is what happened to my 5230 before..suggest u try to contact ur service provider to check ur sim registration details.normally,registration failed when u type a wrong pin code more than 3 times..or try to reset ur phone by press *#7370#...gud luck..
Oct 21, 2012 | Cell Phones
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
Jun 16, 2011 | Uniden Cordless Phone
I need a new operating manual for ModelC-740 ultra-zoom. The registration no. Is 255966787.
You can download the manual in PDF form and/or order a printed manual from the manufacturer's web site at http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=909
Jul 03, 2010 | Cameras
SIM CARD REGISTRATION failed, N70
Factory resetting the phone will do absolutely nothing with this problem
There are 3 causes of Sim Card Registration Failed, when you first turn on the phone, the sim card attempts to connect to the network if it can not do this it gives a message like Sim Card Registration failed.
1, The sim card is turned off (is it Orange) if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
2, The phone has a hardware reception problem, when it attempts to register itself with the network it can not... There is a reception problem and it requires repairs, this isnt really an easy diy job on this handset.
3, The phone is blocked, i.e reported lost or stolen. Some networks when a phone is reported will allow it to get reception but will not let it make calls, however other networks will not give it reception at all and hence you get a Sim Card Registration failed message.
I hope this helps, these are the causes of the message.
May 08, 2009 | Nokia N70 Cellular Phone
GE DECT 6.0 Model 28111EE2 is not working, registration failed message
I had the same problem, and restoring to default settings did not seem to work either. I just opened the back, unplugged the battery, plugged it back in, and now it works again.
Aug 26, 2008 | Uniden Cordless Phone
25802GE3-A Phone -Needs Registration
Remove the batteries from the handsets and wait 30 seconds and then place them back in. It will allow you to register them again.
Aug 18, 2008 | GE 25952 Cordless Phone
Registration
I'm not sure from your description exactly what your problem is, but I have the 28112, and it has a handset menu command for registration, and one for deregistration. If this sounds similar to yours, I'd suggest trying the registration command. If that fails, try deregistering, and then try to register again. I've also heard that these units somehow reset after 20 seconds in the recharge cradle, but I haven't seen that actually appear to work.
If you have problems getting the menu command to work, write back with more info and I'll see if I can figure it out based on what my phone does.
Jan 20, 2008 | Uniden Cordless Phone
Vtech LS6204 1.9 GHz 1-Line Cordless Expansion Handset Logo
76 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
