Question about Makita Saws
Collar fell off of saw and blade fell out - Makita Saws
3 Suggested Answers
  • 2428 Answers
SOURCE: I have a Model 737
Its hot pressed onto the shaft its made not to come apart because if it did in use it would not be good. I use sawalls all of the time and fine if the blade snaps low you can get them out with a strong magnet if you hold it up side down and turn the collar shake it around mabey spray some WD40 in side first it may take a little doing but it beats takeing that change collar a part.
Posted on Jan 14, 2011
SOURCE: I have a tiger saw
Try taking the boot off and removing the shoe, then maybe you can get at the collar to loosen it?
Posted on Feb 28, 2013
How do I CHANGE A blade on a MASTER Mechanic variable speed Jig Saw PP/G30
most blades are held in with a collar if there is no hex screw obvious
pull the shaft all the way back up then pull the collar around the blade up further and the blade should fall out.
May 18, 2015 | Saws
How do you install new blades on a DW7332?
unplug the saw/remove battery
press the button on the side near the blade
pull old blade out. push new blade in, release button to lock new blade in place.
Jun 06, 2014 | Saws
Cannot put blade into 310 reciprocating saw the instructions in the manual do not make it clear
Point tool away from body.
2. Rotate blade clamp collar (the knurled diamond pattern knob just at the back of where the blade goes) to release position.
3. Insert blade shank from the front.
4. Rotate blade clamp collar to lock blade into position.
May 25, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
I'm unable to remove the blade from the quick change something won't release the blade model 6521-21
what you can try is to unplug tool and spray something like WD-40 on the collar mechanism and usually it is simpler for this to remove the pivot shoe and turn the collar and release until you can get full rotation and pull the blade out. There might be some dirt in the release mechanism not allowing the blad/collar to release. This is about the only way without having to remove the assembly. Let me know if you need more assistance
Mar 11, 2011 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
I have a Model 737 Tiger Saw that was loaned out and now I cannot load a blade. It appears that a blade may have been broken off in the quick change collar. I cannot pry it out, so I must disassemble the...
Jan 14, 2011 | Porter Cable VariableSpeed QuikChange...
Blade keeps falling out when jig saw is started?
ther could be an old peice of a broken blade stuck in the collar were you insert new blade
Oct 07, 2010 | Ridgid 26638 Saw R3121 Orbital Jigsaw
The diamond insert in the hub of the blade keeps falling out as soon as I start a cut. What is wrong?
DO NOT USE SAW!!!
1. switch off saw, remove cord from socket (positive electrical insulation)
2. lift table for maximum cut and check size of the washer holding the blade,
3. you should have holding nut with collar, collar is about 1 1/4 (32mm) diameter, then blade (diamond is actually universal reducing bush in some blades) and lastly you should have internal washer, again, about 1 1/4" (32mm) diameter. if your collar are smaller, you need to replace blade as not suitable for your particular model, albeit I am rather suspicious that you have wrong collared nut and internal collar. Please check if both collars are exactly this same diameter. Please check if collars cover diamond cut-out.
4. if you see discreptancy between description in 3, purchase suitable blade (external diameter is 7 1/4" (184mm), as you did not supply what model of your saw, therefore most probably shank is 5/8" (16mm),
5. mount internal bush (collar), will go correctly only in one way.
6. mount blade (pay attention to cut direction, cutting surface should be clockwise if you look at mounting shaft.
7. mount external flared nut
8. check blade for slippage and wobbliness
9. connect power cord and switch on/off
10. check saw blade againg for slippage/wobbliness
11. make test cut if 10 was correct
12. use normally
Do not forget that this is not a toy, it will cut through wood, ocassional nail and your fingers.
Opearating saw crate flying debris, always wear googles or facemask, you have only two eyes and there is no spares.
Please leave note how you go with this advice.
Aug 18, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
I have a Sears 10 inch bench top table saw. Model 133221770. purchased in 1998. Lost the ''collar blade''. Sears stopped making the part, can I substitute or where can I find one?
If you can measure the arbor size, (the spindle the blade goes on), just buy any collar that will fit. The basic purpose of the collar is to spread out the force over a larger area of the blade from the arbor nut when it is tight.
Jun 08, 2010 | Craftsman Saws
I do not know how to install blade and have no manual
Most of the skil jigsaws have a plastic piece with a spring and catch behind it. Just push your blade into the tool and it should lock. When you want to remove it you need to press the plastic lock collar up and it will release the blade. Some of the earlier models weren't as easy to set the blade in and you have to press the lock collar up insert the blade and let the collar down around the blade to lock it.
Sep 09, 2009 | Skil Saws
How does one remove a broken blade from a Bosch rs20 blade holder
twist the collar around where the blade fits in the saw. It will lock in the open position. When you insert the new blade, do so firmly until the collar releases locking the new blade in place. Give a tug at the blade to make sure it is locked in.
Nov 27, 2008 | Bosch RS20 13 Amp Reciprocating Saw
Saws Logo
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
