Question about Kitchen Ranges
Dacor prg30 will not heat up - Kitchen Ranges
Temperature does not go lower than 44 degrees
our dacor required a complete rebuild. new compressor, new heat exchanger with all new piping and of course a new charge of refrigerant. a total of 14 man hours, both journeymen. the refrigerator is 7 years old at time of rebuild.
dacor covered the parts, i paid the labor. the repair company is an approved dacor representitive. don't use a company that does not know dacor products.
Nov 30, 2013 | Dacor Epicure EF42BNDB Side by Side...
Dacor Model# ERD36, Oven Element no heat & no error code flashes.
look for a hi limit thermo in burner box or on back of oven . if it has over heated this would cause this . dacor has a resetable one . it may be located on left side panel will have to be removed . ck elect sch tof location .. mm
Dec 04, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
Oven does'nt stay on.
SOUNDS LIKE TERMOSTAT REPLACE THIS AND OVEN SHOULD WORK.
Oct 13, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Our Dacor Millennia wall oven will not heat
There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
Dacor rsd305
yes, you need to open the panel (in the center of the front of the oven when you open the door on the top) and press the reset button, there is a site that gives step by step instructions, but i can no longer find it
Jul 22, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Dacor epicure electric oven
On my Dacor oven whenever I use the self cleaning feature it trips the breaker and the oven doesn't heat up. It can be reset, but you need to take off the front panel and reach way back for the red reset button.
Nov 04, 2007 | Dacor ECS130 Epicure Electric Single Oven
Kitchen Ranges Logo
15 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
