Question about Vehicle Parts & Accessories
How to disarm cobra 3171 - Vehicle Parts & Accessories
Gsxr1400 spyball will not disarm have tried all reset procedures i got with the bike . can anyone shed any light on this
Hi, Nikki you may need to contact Cobra for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Cobra SPYBALL 6829 User Instructions
http://gsx1400fe.co.uk/gsx1400_manuals/gsx400_full_manual_k2_to_final_edition.pdf
OEM parts for Suzuki
Suzuki gsx 1400 Owners manual
Jul 21, 2016 | Motorcycles
How do i disarm cobra 7910 car alarm
Try getting in touch with the factory. You are not the only person who has encountered this problem.
Feb 07, 2015 | 1998 Ford Escort
Cobra4100 will not disarm
Hi Mike,
Your 2-way will not disarm?
Okay, I'm confused, are we actually talking about a 2-way radio or a car alarm?
The more info you give, the easier it is to assist you.
Please reply with as much detail as possible.
If in fact this is a car alarm, then the good folk at Cars & Trucks forum will gladly help, but the more info you give us, the quicker the answer you'll get.
Regards,
Peter
Feb 19, 2013 | Cobra microtalk pr 4100-2 wx vp - two-way...
Hi need disarming cobra g193 alarm,have keyfobs.almost everytime i disarm alarm door locks start to play up(sounds like them trying open and close open and close) sometimes its even start doing during the...
I would recommend disconnecting the alarm and having it checked out by a qualified installer. It sounds like there may be a problem with the brain of the alarm itself. Disconnecting it will prevent the motors from burning out.
Feb 04, 2011 | Vehicle Parts & Accessories
I have a Casio 50M. I can't stop the alarm function. It seems to beep when it wants to. This watch has the REM feature. Help !!!
Hi trapmanjohn,
Man what an aggravating problem! Try this procedure.
1. To turn the daily alarm and time signal on and off:
2. In the Alarm mode, press "B" , upper right button, to cycle throught the on and off settings as follows:
Alarm on Indicator/Hourly Time Signal On Indicator
a. }}}} with Bell = Both alarms on
b. Display Blank = Both alarms OFF
c. }}}} = Daily alarm on only
d. Bell = Hourly time signal on only
The Alarm ( }}}} ) indicator flashes while the alarm is sounding.
The Alarm ( }}}} ) indicator and hourly time signal on BELL indicator are displayed in all modes.
To Test The Alarm: In Alarm Mode, hold down the "B" to sound the alarm.
Your Module number is #3171. Down an Operation Guide for the 3171 from here for more clarity:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3171.pdf
This should help you with nuisance...Good luck.
Regards, Bill
Sep 08, 2010 | Watches
I tried to start my car this morning it makes a ticking noise and it doesn`t start. and alarm isn`t going.I have cobra 3190. How i can remove the alarm? plzz some help?
if the ticking noise is coming from the engine compartment, you have a dead battery. some alarms will not function when the voltage is too low, therefore you can't lock/unlock or arm/disarm the alarm.
Feb 21, 2010 | Vehicle Parts & Accessories
How to reset cobra 3198 alarm
I have the installation and users book for the cobra 3100 series G193 3193 series
if you want a copy email me and I will scan and email a copy to you, It has how to reprogramme remote controls, reset the system from the main panel and how to disarm if required
judd28@tiscali.co.uk
Oct 07, 2009 | 2006 Honda Fit
My Mustang Cobra has a Viper alarm system that won't set
Under the dash, Your installer that worked on your Cobra should have put an valet button under the dash, It is a small round Black button, Ok with the driver door open,,put your key in the ignition and go to the on position, Locate the black button before you do this, once the ignition is on hold the black button down for 3 seconds hit it once more and then turn the ignition off, the light should start flashing again and the chirp for arm and disarm with work again, What you have going on is called Valet mode which is designed to put the alarm side of the system to sleep which can happen from accidentally bumping it.
Hope this was helpful.
That Crazy Install Guy.
Apr 05, 2009 | Vehicle Parts & Accessories
Cobra immobiliser key
After ages searching finally found this on the Cobra site.... A8510 KEY PROGRAMING Ensure the immobiliser is disarmed :- 1) Switch the ignition ON and OFF three times then back to the ON position within seven seconds. 2) The LED on the dashboard will light up signaling the unit is in programming mode. 3) Touch an already programmed key onto receptical, the LED will extinguish for one second 4) Repeat step 3 for all other keys (Max of 4 touch keys) 5) To exit programming switch off the ignition key (unit will automatically exit programming after four keys) NOTE :- 1) Programing procedure can only entered with the system disarmed. 2) If all keys have been lost the system will need to be replaced
May 24, 2008 | 1994 Land Rover Discovery
Vehicle Parts & Accessories Logo
26 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
