Question about Soundstream VIR-7830 7-Inch Lcd TouchScreen CD/DVD/MP3 Player Usb/sd
Screen wont open - Soundstream VIR-7830 7-Inch Lcd TouchScreen CD/DVD/MP3 Player Usb/sd
I reset my tablet and it still wont open up to the main screen
What make and model? May be you need to reflash it
Feb 17, 2017 | The Computers & Internet
I have an lg350, touch screen. It is very temperamental at times. When i try to open up the phone by sliding the screen it wont open. been at it now for ten mins please help
Hello there,
The problem is that the screen is weak and needs to be calibrated. You wont be able to access the calibration settings unless the phone is opened. Try to remove the battery and insert in back in, then the turn on the phone, try to go to the menu and select the settings of the phone, then you select calibrate screen, and follow the rest of the instruction from there on, that way the screen will be able to work well.
If you eventually do not have access to the phones menu, you will have to replace the sensor board of the phone.
Hope this helped.
Goodluck
Elect_Comp
Aug 09, 2011 | Cell Phones
Clarion vrx486vd cd player wont open screen
help e find an installer for my hp dekjet 2300 series printer
Feb 16, 2010 | Clarion VRX485VD Car DVD Player
My computer will not open any programs or cd drive wont open. When I try to open a program the command prompt screen comes up and then closes but the program wont open
YEOW... not fun...
Reboot ---> as soon as you see the very first opening screen (the manufacturers screen, BEFORE the windows screen) press and hold F8 --> the menu that appears will give you some options, choose "Boot in Safe Mode" --> When Windows loads, it will either give you the option immediately to run System Restore (or go to Start ---> Help & Support --> System Restore)
Either way, if the computer is attepting to open a command prompt from a normal icon, you have issues! Try to restore it first to a date sometime before the problem started!
Hope this helps!
-- RT
Sep 02, 2009 | Dell Latitude C610 Notebook
Hp pavilion dv4000 screen wont turn on
Try this quick fix first. Remove the battery, unplug the ac adapter and hold in the power button, plug the ac adapter back in and turn on.
Jun 20, 2009 | HP Pavilion dv4000 Notebook
V3 wont recognise when flipped open.
It means ur handsets display strip occured problem
there is only one solution that replace the STRIP
May 19, 2009 | Motorola Mobility RAZR V3
Avh p6600 screen wont come out ,comes out like once a month
if green wire is connected to ebrake then pull the ebrake and it will open, if you want it to open while driving you have to wire green to ground.
Oct 22, 2008 | Pioneer AVH-P6600DVD Car DVD Player
Dvd player wont open
the door will not open at first it would open and close real quick, now it will not open and then it quits too, thanks jon
Jul 02, 2008 | Sanyo DWM-380 DVD Player
Soundstream VIR-7830 7-Inch Lcd TouchScreen CD/DVD/MP3 Player Usb/sd Logo
14 people viewed this question
Top Soundstream Video Cameras Experts
Are you a Soundstream Video Camera Expert? Answer questions, earn points and help others
