Question about Canon F-502 Calculator
Number keys don't work
Only numer 1 works
The numeric key pad on my keyboard does not work
There's usually a Numlock key that turns off the cursor movement and turns on the numeric keys. If it doesn't say "Num Lock" or something similar, you might need to press the Fn key with the F1-F12 key that looks like a numeric keypad. Pressing the Shift key while pressing a number on the numeric keypad should give a number output if the Num Lock is turned off, the cursor movement if Num Lock is on.
Jan 25, 2018 | The Computers & Internet
Kenwood hdv 770
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key "5" ( 2 times ) and press the Track UP/Next Track key
* Press numeric key "2" ( 3 times ) and press the Track UP/Next Track key
* Press numeric key "2" ( 1 time ) and press the Track UP/Next Track key
* Press numeric key "7" ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Jul 20, 2013 | Vehicle Parts & Accessories
I need the code in order to use my cdplayer
One of the following procedures to clear the security code should work:
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that "..." disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing your "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. If your code number is 5227 (KCAR)
push button "track up" for 3 seconds
The security is canceled and the set enters the TUNER mode.
Mar 14, 2011 | Kenwood KDC-MP4032 CD Player
I need the reset code for a kenwood kdc-mp342u
Your code number is XXXX (KCAR)
i am also pretty certain that you will need to use the remote control to input your code.
If this master reset does not work, the unit will need to be sent to kenwood with proof of purchase for them to reset it. ................... in saying that I am yet to hear of this procedure not working.
hope i helped, and please dont forget to rate my solution. :-)
cheers
Jan 15, 2011 | Kenwood KDC-MP342U Car CD Player
My F9 key is locked
Per the Owner's manual, just press the NumLk button once to toggle the number lock off.
" Unexpected charactersDisable the numeric keypad —
Press <Num Lk> to disable the numeric keypad if numbers are displayed instead of letters. Verify that the numbers lock light is not lit."
http://support.dell.com/support/edocs/systems/ins1501/en/om_en/html/trouble.htm#wp1062918
Mar 27, 2010 | Dell Inspiron 1501 Notebook
My dvd/stereo won't play dvd's unless grounded to emergency brake
There are a few types of override procedures for Kenwood.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Type 2
Type 3
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
"TRACK UP BUTTON" for 3 seconds.. and youre done.
Aug 24, 2009 | Jensen VM9510 Car DVD Player
Radio lock
Try this if it works to your unit;
Type 1
Type 2
Type 3
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Sep 07, 2008 | 2001 Chrysler Sebring
Cd code on radio kenwood
You need the remote control to clear the code, if you don't have one, then you may need to go to a KENWOOD agent, or purchase one for your use.
KENWOOD SECURITY CODE CLEAR procedure Your code number is 5227 (KCAR)
Type 1
Type 2
Type 3
Please rate ne FixYa for this solution. Good Luck :)
Jan 30, 2008 | Kenwood KDC-MP4028 CD Player
Security code not working
y this
Type 1
Type 2
Type 3
Jan 10, 2008 | Kenwood EZ500 CD/MP3/WMA Receiver
Kenwood MP4029 4 code reset
Type 1
Type 2
Type 3
Oct 13, 2007 | Kenwood KDC-MP228 CD Player
Canon F-502 Calculator Logo
22 people viewed this question
old marine
old marine
