Question about Mitsubishi VS-50603 50" Rear Projection Television
Mitsubishi 50" Projection TV (Model VS-50603) Has sound but no picture
After a recent power outage in my community my TV stopped projecting a image on to the screen.  This TV is connected to Direct TV satellite which is still functioning properly.  When I go into menu mode using the Mitsubishi remote I get a Picture-in-a-Picture (PIP) which is high quality.  I can see where the Direct TV remote commands operate fine in the PIP while in menu mode.
We have owned this TV about 10 years.  I have surge protection devices on all the components connected to this TV as well as the TV itself.  What might be the problem?  Is there anything I can do to verify without getting to involved in the troubleshooting process?  Is this likely to be such an expensive repair that replacement is a better option?  Please advise.
Thanks in advance.  Michael Bazemore (bazmonet@hotmail.com)
  • Anonymous Nov 10, 2007
    Same Problem.
MJBNATL:
I reluctantly scheduled a technician to come out next week and take a look at my set. I was going to pay, at minimum, $65 for the service visit. I was then blessed with the intutition to do a bit more research regarding the PIP box being stuck on my television and other input functions (Inputs 1,2, and DVD) being unavailable.
I stumbled across a post on the internet that mentioned that the VS50603 can reset certain error conditions by pressing and holding the Input and Menu buttons (simulatneously) on the front panel on the TV while it is off. At some point after initiating this internal reset the LED light should starting flashing at defined intervals. The number of flashes correlate to a particular error code. Please go to the Mitsubishi website and download the owners manual (VS50609 in my case, couldn't locate VS50603) to lookup what the various error codes mean.
It seemed to me that that the LED flashing did not start immediately after pressing the Input and Menu buttons. In fact, I awoke the next morning to find the TV off but the LED flashing 10 times, pausing briefly, then flashing 10 times again. The sequence of the flashes mean something. Here again, consult your owner's guide for specifics.
Long story short, after awaking to find the LED flashing, I then turned the TV on and voila-my big screen was back minus that pesky PIP box prominently displayed.
I hope this helps someone like it helped me!! Truly a Blessing for sure.
Michael in Atlanta
Posted on Dec 30, 2007
Mitsubishi VS-50603 50 in. Rear Projection can i replace the mirror myself
First of all you need to check with the nearest service dealership for the availability of the mirror and the cost of the unit. Normally the cost from such dealerships will include to an extend the replacement cost and so it will be wise to have it done in the first case than to set it up and watch a distorted image if the aligment is not proper as the fall could also have shifted the alignment.
Nov 30, 2011 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
NO SOUND OR PICTURE JUST SNOW WAS WORKING FINE THE DAY BEFORE
Check the tv with another cable signal or another tv with that cable signal.Both check,same things happen.Ur tv digital tuner is dead.
Sep 24, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-50603, input is gone
happened to me also. Go to the menu, select setting, thrn av (home theater) and see if "locked to input 1" is "on". Mine was. then I set it to "off" and everyting works great
Dec 06, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi VS50603 will not turn on
If you are not a tech the tv needs to go to a tech to be fixed.the probleis in the power supply or related circuit good luck.
Apr 01, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Televison & Video Logo
697 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
