Question about Refrigerators
Freezer Door Following up my previous question asking why the bottom freezer door does not shut properly and stays open a good inch. First, the problem has nothing to do with the fresh food door above (I believe) since it is closed and not touched when the bottom freezer door is closed. When the bottom freezer door is closed in a normal manner, it pops back open immediately as if something is blocking it from closing but there isn't anything. No matter how many times I try, it always pops back open an inch or more. HOWEVER, when the tray in the freezer is pulled back towards the freezer door AND THEN the freezer door is closed gently and slowly (really slow) the freezer door will stay shut. For how long I don't know since this refrigerator is in a tenants house and I'm just starting to work on this problem. So, experts, what do you think? Mikael
  • Refrigerators Master
  • 19,031 Answers
There is usually some adjustment on the hinges. Your is termed buttbound, the door at the hinges is too close so it makes the door pop open. Take everything out of the inside door shelves if there are any. Slacken the mounting screws a little and pull the door away from the frame, make sure it sites square and tight, and then tighten up the mounting screws. With a freezer, i would also suggest fully defrosting it first.
Posted on Mar 15, 2017
HVACRH20
  • 237 Answers
SOURCE: freezer door won't stay shut
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Posted on Nov 10, 2006
IFIXALL
  • 868 Answers
SOURCE: Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Posted on Jun 06, 2008
  • 489 Answers
SOURCE: LG bottom freezer
Sounds like the refrigerator is sitting lopsided.  Make sure that the front legs are both retracted in the up position.  If it doesn't work, then lower the front leg on the hinge side of the refrigerator.  That will cause the frame to lift the door and it should be able to close properly.
Posted on Jun 08, 2008
  • 12 Answers
SOURCE: Kenmore - over under
Adjust the feet to raise the front of the frige, which should be higher than the back. Therefore the weight of the door will keep it shut or at least cause it to shut itself if it pops open.
Posted on Oct 05, 2008
stradeteox
  • 88 Answers
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Posted on Jan 18, 2009
How do I fix a freezer door that pops open when the refrigerator door is closed ?
Good Afternoon Friend, this is Z. I appreciate your post!
Often when one door is closed and the other opens, it is because either the hinges are damaged or your refrigerator has a poor door sealed. Trying checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocking by anything stopping it from closing. If the gasket is not sealing properly, it may possibly near replacing. Since there are cost differences in parts it is always a good idea to have a certified technician properly diagnosis your appliance. Best regards!
Aug 05, 2014 | Frigidaire Refrigerators
Bottom freezer door will not stay closed.
Check the hinges and the door seal. If you need parts Sears service center online has a great parts locator for kenmore
Feb 18, 2014 | Hardware & Accessories
Freezer door will not stay shut is their a replacement for the maginetic strip bottom freezer small
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 21, 2009 | GE Refrigerators
Freezer door won't stay shut
Jan 18, 2009 | Refrigerators
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Jul 08, 2008 | Kenmore 62832 / 62834 / 62839 Bottom...
Whirlpool fridge freezer
trying to open door?? does it feel as if top wants to open ad bottom of door is being stuck shut? or mabye a package of frozen food has shifted of a shelf and is holding the door shut, if so brute force will solve that one.if it feels like held at bottom sounds as if youmight have a clogged defrost drain tube.drain water backing up onto freezer plor and holding door shut. even then forcing door open is only way then removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over.
Feb 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
LG bottom freezer
Oct 25, 2007 | LG LRDN20720 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
