Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Linksys BEFSR41 I am trying to re-install my Linksys BEFSR41 and it will not complete the installation. It stalls at the password screen. It will not take the default password (admin) or the new password I entered when first installed the unit. My computer needed to be restored to an earlier date.
  • 193 Answers
Re: linksys BEFSR41
K do reset the linksys-look @ the bottem u can see a red hole reset>and put the power on to the device and take a pen or paper clip>press it and hold it for 40 seconds with power and relese and reboot and u can use the default one which is (admin) as user name and (admin) as password all lower case>and rate me solved if its helps
Posted on Oct 29, 2007
0 characters
3 Points
I have a linksys befsr41 but I do not have the installation cd and I am using OSX 10.6.4. Please help! Merci beaucoup
When you connect your router using an Ethernet port you don't need any driver.
To access the configuration and setup of your router open your internet browser and in the address bar enter and then press enter.
By default user is blank and password is admin
Here the manual and installation guide for your reference
Jan 31, 2011 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I lost my installation cd for the linksys BEFSR41 ver. 2.0. how do install now
Here's a link to the Linksys site and the downloads you need. Choose version 2.0 and you will see the downloads available...
Nov 12, 2009 | Linksys EtherFast Cable/DSL Router
Install router on windows XP
you could download the quick start from for that but basically there is no installation necessary with windows, it's a network device that does not need to be installed. simply plug it in.
Jun 09, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Setup and confifuration of my linksys befsr41 ver 2 router
Since you did not include your exact model number and type of internet provider I cannot give you more specific instructions. Although you can refer to the links below on how to set it up. If you require further assistance just reply to this and give me the model number of your ISP and the model of your router. Also answer this question " When you plug your computer to your modem do you get online automatically or do you need a username and password"
Dec 17, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Router install ok, but don't connect to internet
if you are from the east coast,you need to configure your new linksys router for a ussername and password which is usually provided to you by your Internet Service Provider
if you are from the west coast,after you connect the new linksys, you must be good to go for internet usage.
Dec 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys router limits speed to 5 meg.
Try to access the router's setup page and change the MTU settings. The default address for the Befsr41 is Here are instructions:
1) Use a computer wired to the router.
2) Launch a browser and type in, leave the username blank and the password is admin or the password you have set when you first configured the router.
3) Click on the Advanced tab then click on the Filters tab. On the bottom part you have MTU.
4) Enable that option and set MTU to 1500, 1400, 1300 (for cable ISP connection) and 1492 (for DSL connection) and check if it will work.
4) If that does not work, you can try upgrading the firmware of your router.
Apr 29, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Lynksys BEFSR41 hookup
To hook up your lynksys router plug your internet connection wire in the back of the router where it says linksys then run another cable from the slot one to your computer, when you first get your router your username and password will be admin type your IP address into your internets browser window and use your username and password to log onto your linksys router, choose your router settings and there you have it,
Good luck
Feb 19, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys BEFSR41 keeps cutting out online.
Try reseting it, to do this hold the reset button on the back for 30 seconds, this will reset the router to factory defaults and your username and password will be admin.
Feb 17, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
164 people viewed this question
Top Linksys Routers Experts
 C. Dante
C. Dante
Are you a Linksys Router Expert? Answer questions, earn points and help others
