Question about Dometic RM2620 Refrigerator
Fridge section freezes everything - Dometic RM2620 Refrigerator
    Top Expert:
  • Dometic Master
  • 6,949 Answers
Move temp sensor in to center of coil if same replace sensor
Posted on May 27, 2016
2 Suggested Answers
  • 20 Answers
SOURCE: fridge freezing everything
If your fridge is freezing to much put the thermistor closer to the fins (it will make it colder so it shuts off sooner)
Posted on Feb 02, 2009
Why the heat exchanger between the freezer section and the fridge section freezes up around the second element closer to the door and makes ice on the roof of the fridge section.
If your freezer is icing up it is the defrost mechanism consisting of the timer, heating element, and defrost thermostat.
When you unplug unit everything melts and it runs fine for a few days till it freezes up again.
Usually it is the heating element that just burns out and has to be replaced.
Sep 14, 2015 | GE Refrigerators
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
I have a whirlpool s20brsb21 and all to often everything freezes in the fridge compartment for no reason
Make sure that the fin tubes on the back are not loaded with dust, clean off and don't over load the freezer section. If there is no room for air flow the temperature will keep getting colder to compensate for low air circulation, thus freezing items in the lower section.
Feb 07, 2012 | Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Dometic rm2652 fridge section freezes everything
Hello Keith,
Just came across your question, hope its not too late to answer.
Your freezing problem for the fridge section is likely caused by
1) the thermistor has worked itself loose from the cooling fins.
2) the thermistor is no longer on third fin from the right
3) the thermistor is failing.
Jun 26, 2010 | Dometic RM2652 Refrigerator
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Oct 09, 2009 | Fisher Refrigerators
Fridge keeps freezing everything!
you need a damper door and thermostat asm. the door that allows the cool air in is just staying open that is air from freezer and if open all the time will cause your freezing temp in refrig section you can take some tape and cover 3/4 of the grill where you feel air coming out in the frig section to help slow the air it is in the top left hand corner in the back you will feel air. should get you until you can get a repair man.
Feb 17, 2009 | Frigidaire FRS26R4A Side by Side...
Fridge freezing everything
Nov 01, 2008 | Dometic RM2652 Refrigerator
Hoover HCA300FK Frostfree fridge freezer
thermostat is not turning off.replace the thermostat
Aug 09, 2008 | Refrigerators
Dometic RM2620 Refrigerator Logo
22 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
