Question about Kodak Easyshare Z5010 14MP Digital Camera
Flash not working - Kodak Easyshare Z5010 14MP Digital Camera
Why are Flash videos not playing on my computer,especially Firefox 30. Any suggestions?
You probably have to unistall flash on firefox.
  • Go to adobe flash download page. 32 bit or 64 bit for your system configuraton
  • Make sure you check that the latest version is available (which will show in the browser window)
  • Download the flash uninstaller. Scan with your AntiVirus
  • Run the uninstaller then reboot the system.
  • Then install the flash update download
Adobe Search flash
Uninstall Flash Player Windows
Jul 05, 2014 | Mozilla Firefox
Canon sx 150
Hi
1. The flash on this model Canon works only if you manually raise the flash. It does not rise automatically, and is only on the raised flash.
2. Flash on the module has a switch - it sometimes fails and then flash "does not understand" that she had to get involved.
3. Not working flash capacitor charging circuit - usually after any water
4. Flash lamp is not working - usually after a light blow
5. Command does not work (a piece circuit) from the processor to light the lamp flashes - after a blow or hit the water.
If you follow steps 1 - Raise the flash and the camera is turned on in the menu mode - "shoot with the flash" - but your flash does not work - the rest can fix broken only engineer to repair.
Oct 23, 2012 | Canon Powershot Sx150 Is 14.1 Mp black...
Flash will not work
Before you give up on the camera:
There are many setting that can affect whether the flash works or not.
You may have inadvertently set something that is stopping the flash from working.
Get out your User Manuals and use the index at the back of the book.
Look for something about "Resetting the camera".
This will reset the camera to factory specifications.
Then see if the flash works.
If that does not work ... recharge the battery and try again.
If that does not work, the flash is likely dead.
May 30, 2010 | Canon PowerShot A590 IS Digital Camera
The flash does not flash. Camera works without the flash.
I reviewed the menu settings and made a change to the flash option setting. Some how the function was turned to the off position!
Reading your posted comments gave me the idea to check that out!
Thanks, TW
Aug 24, 2009 | Canon Cameras
Flash does not work
Ok,
Flash unit is defective and needs to be replaced as per following part number... (if you have camera repair experience then can do it your self because electric shock risk in involve in flash unit handling)
A-1249-950-A ..ST BLOCK ASSY
Above part is available in Part Store.
Dec 26, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Minolta Maxxum 3200i Flash does work
Try to short out the flash and see if the flash flashes.
Remove flash from camera.
New or fresh bateries installed.
Get wire with insulation and remove both end bare to 1/4"
Turn on flash and wait until light turn green or ready.
Touch one lead to center of flash pin, touch other end to the outside(rail on the side) pin.
Flash should discharges.
atdlee@netzero.com
Jul 28, 2008 | Cameras
Auto Flash 200x doesnt work ???
CoolSmith,
try a non dedicated flash unit, if the flash works then the 200X is not compatible to the xg1
if the flash did not fire, there is a circuit problem. there are no new parts for this model.
Mar 09, 2008 | Minolta XG-2 35mm SLR Camera
Flash not working
I had the same problem with my flash not working on any setting, but I found a way to fix it: hit the menu button, make sure the "rec mode" choice is set to normal instead of burst. I think the burst mode takes multiple shots in a row, so the flash isn't compatible with that setting?
Feb 15, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Canon EOS 1000F in-built flash unit
Set camera body for Internal Flash for Pop-Up Flash.
Set camera body for External Flash for parked flash on Hot Shoe.
atdlee@netzero.com
Nov 08, 2007 | Canon EOS-3 35mm SLR Camera
Kodak Easyshare Z5010 14MP Digital Camera Logo
19 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
