Question about Refrigerators
Westinghouse virtuoso fridge is freezing. adjusting temp on door panel doesn't work.
Freezer works ok - problem is fridge freezing everything and makes no difference what temp chosen
    Master:
  • Refrigerators Master
  • 676 Answers
Is the fan operating in the freezer section? If not there is your problem. It the fan is working then it could be the damper or the temperture control.
Posted on Feb 14, 2014
SOURCE: Westinghouse virtuoso fridge/freezer has stopped
I have the same fridge (stainless steel virtuoso) and when the fridge section stops cooling you have to turn power off. Then remove everything from the freezer including the shelf. Next get a pointy object and remove the two plastic screw covers located on the back inside plastic freezer panel, Next remove the two phillips head screws securing the panel in place. Next (and this is a little tricky) get two solid forks and lever the back interior panel off, thereby exposing the cooling system of the fridge. Next get a hairdryer and completely defrost this item, and then reassemble. Switch power back on and your fridge will be fixed, and cooling like a champion! plus you have saved hundreds by not paying ripoff "technicians" I have to do this every six or seven weeks because of the high humidity here in Darwin, the freezer is "frost free" but the cooling system still ices up, and this is what blocks airflow and stops the fridge cooling.
Posted on Dec 27, 2011
xalint1
  • 150 Answers
SOURCE: fridge not cold freezer ok
More then likely your problem is that its not defrosting correctly in the freezer and the ice has built up behind the panel and not allowing the cold air down into your refrigerator.
Posted on Aug 22, 2008
  • 5 Answers
SOURCE: Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Posted on Nov 15, 2009
  • 4793 Answers
SOURCE: westinghouse virtuoso fridge door wont shut. it is
SPACER WASHER ON PIN HINGE GON AWOL/REPLACE IT..if can lay unit over to get to screws on bottom hinge of unit underside, awkward/heavy, not on your own please ,this mother is heavy.........
Posted on Feb 08, 2010
SOURCE: samsung RB215BSSB refrigerator freezes up
I had a similar problem where my evaporator coil was freezing into a block of ice, which caused my fridge to warm up due to a lack of air flow. I fixed this by doing a few things. I replaced the circuit board ($100) which was easy to do. Unfortunately, this didn't fix my problem so I took the inner fridge cover off to view the evaporator/heater coil assembly. I checked my thermo fuse and found it to be open (failed). I ordered the thermo fuse and the thermistor and replaced them both. I then plugged the fridge back up and put a regular thermometer inside the fridge to get an accurate reading of inside temp. A few days now and everything looks good. The board, fuse, and thermistor were all pretty easy to replace.
Posted on Sep 19, 2010
New Westinghouse fridge cannot seem to adjust freezer lower than 0' except if power freeze on getting colder ?
read the user manual or get a technician out under warranty
from 10 down to 0 on a fridge is getting colder with the smaller numbers
with a freezer 0 to 10 gets colder as the numbers get bigger
Jun 05, 2016 | Westinghouse Refrigerators
Westinghouse virtuoso freezer alarm will not turn off, why?
the alarm on virtuoso/ westinghouses are generally a high temp alarm
meanning the freezer has not reached its set point temp . it could be caused by many problems . i would suggest you get a tech to diagnose it properly .
Oct 03, 2014 | Westinghouse Refrigerators
Westinghouse virtuoso fridge- my top panel has gone blank - and everything in my fridge is now freezing - is there an easy solution to fix this ??
Sounds like the thermostat has failed to on and the machine just keeps freezing. Before replacing the panel try turning the power off to the fridge at the wall for 2 minuites and then return the power.
Apr 05, 2014 | Refrigerators
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
Fridge is freezing....
The way you've stated your problem is confusing? The temperature is the freezer should be 5 degrees F or below, preferably at 0 degrees F. The refrigerator side should be anywhere from 34 - 38 degrees F, What exactly is the problem your having, fresh food not cooling but freezer works ok?
May 07, 2012 | Westinghouse Refrigerators
White Westinghouse ( Model# MRT 18FNEWO
refrigerators only have one cooling system and that is for the freezer. The fridge part is cooled by sending a portion of the air from the freezer to the fridge. your fridge thermostat controls a fan that turns on and off as needed. first step is to make sure this is working, and not stuck on. turn your fridge to a somewhat warm no and open the door for a few minutes to allow the cold air out then check and see see if it gets very cold again within say an hour. if it does your fan is always on and you need to repair it. if that is working then you have to play with both freezer and fridge settings. best thing is to get a cheap thermometer and check your freezer temp. it should be around 0 to -5f if it is colder than that frigid air blowing into your fridge too cool the whole area will freeze anything close to the vent. once you have your freezer set then start adjusting your fridge. personally I have mine set at 34f knowing that some things on the top shelf will freeze. but I like my cola's COLD. so I put things like butter that are harder to freeze at that level. but if you don't want anything to freeze then a temp of 37 -39f is correct for your fridge. so it comes down to freezer temp, the amount of time the fan is on, and proximity to the vent. good luck
Nov 24, 2011 | Refrigerators
I have a westinghouse 2 door fridge that is not getting cold enough, 7 degrees in the fridge, freezer seems ok. not sure where to set the controls as i have no manual. its a 2 door,freeze at the top and...
i think your ref working normal try to adjust thermostat setting on the fridge if you want to cool lower than 7 degrees but this temp. allready can chill the food. then you said that freezer ok.
Feb 12, 2011 | Westinghouse Refrigerators
Not only will the fridge side not cool properly, now the door won't stay shut. Temp in fridge side stays 20 degrees warmewr than what panel says.what a pos.
Fridge problem- How to check everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Door problem-The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Aug 22, 2009 | Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Westinghouse virtuoso fridge/freezer has stopped cooling. How do we check the fuses etc? seals on the doors are all fine.
Aug 03, 2008 | Refrigerators
Refrigerators Logo
441 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
