Question about Mitsubishi WD-65733 65" HDTV
SEVERE WATER DAMAGE
THE TV WAS BEING MOVED IN THE BACK OF A TRUCK AND IT STARTED TO RAIN NOW THE BOTTOM HALF OF THE SCREEN IS BLACK
2 Suggested Answers
jomaru
  • 337 Answers
SOURCE: Half a picture in black
Witch part of the screen you loose?if is the bottom or the top it could be a problem in the vertical IC circuit if is the left side or the right side is a problem on the horizontal deflection circuit(very rare),try taping on the set when it does it and see if the pix reacts ,if it does one way or the other you have loose conections and some resoldering need to be done.If you are familiar with tv circuitry you will have no problem.If you are not be safe and call for help.
Posted on Sep 19, 2006
Black line through middle of emerson led tv screen
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD panel are given. You can compare it to that of your TVs'.
Apr 23, 2014 | Emerson Televison & Video
While watching tv half the screen goes black
Download software from the Phillips web site. Use a usb flashdrive to transfer the download to the TV. This worked well for us and our picture is better than ever.
Apr 09, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Dropped my phone, half white/half black screen.
Repairing the damage to your phone cannot be performed 'at home'. You'll need to take (or send) it to a repair center to determine the amount of damage it has sustained and the exact parts that will be needed to fix it properly.
If you have insurance on your phone with your cellular provider you can have it replaced -as cell phones being dropped are covered by most insurance policies.
Take the phone to one of your cellular providers Retail Stores that has on-site tech support and repair. They will be able to perform a more accurate assessment of the damage and cost to repair it.
Apr 08, 2010 | Cell Phones
Fault with Samsung PS42S5H
sounds like the lower y-sus buffer! take off the back and give me the pcb number should start with Lj92
Nov 03, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Sanyo dp42746 half screen blacking out
http://cgi.ebay.com/philips-plasma-Y-board_W0QQitemZ270262136649QQcmdZViewItem?hash=item270262136649&_trkparms=72%3A552%7C39%3A1%7C66%3A2%7C65%3A12&_trksid=p3286.c0.m14.l1318
Jul 20, 2008 | Sanyo DP42746 42 in. Plasma Television
Screen went BLACK!
My Sony FD Trinitron TV did samething, started flashing, then eventually went completely black with volume. I got on internet searched found a solution, i tried it, it worked. unplug tv, remove all screws, remove back. towards bottom right theres a transmitter with a couple of knobs, we plugged tv in and moved knobs around and it worked. Also was extremally dusty, we used computer duster for a better connection. hope it helps you
Jan 26, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
The TV is only showing half of the picture
Hi Bigtate,
There is not much for me to go on with your description but here goes,
I suppose you have a convential TV set with a glass picture tube and not one of the new types with the large screen slim style displays!!!
If it a glass type picture tube then the following assumptions are made.
I hope yopu have not shifted house recently and moved the TV around???
If you have its possible the Yoke (its a device on the neck of the Picture tube that controls magnetically the scanning dot) may have moved and only is letting you see half a picture...
This is a long shot but it could be the cause..
Now the picture is supplied to you by a fast moving dot of light (Black & White set) that scans from the top of the picture and moves very fast down to the bottom of the screen, then flys back to the top of the screen and starts all over again during this process the dot lights up the picture tube to provide you with
the picture you see... (On a colour set there are three dots)
Its quite a complex process and its all controlled by electronics inside the TV receiver.
If you are getting only half a picture then something is causing the dot to only turn on for the lower half of the picture during its write time to the glass screen,
You dont say if the half thats off is white or black, so there are many things that the service technician needs to know before even starting to look for this fault. During the dot doing its write cycle down the sceen, when it reachs the bottom and flys back to the top of the screen it receives a synchronous pulse from the TV station, and this TV signal is critical in making sure you see the same picture as is being sent from the TV station.
Sometimes this sync pulse from the TV station is very weak and so your picture may float up and down the screen trying to lock to the incoming signal.. this just may be your fault.. but you dont say if the half of the picture that you see is floating or not..
Your situation may be that your TV has partially locked to the station signal and your aerial may be problematic,
but then you dont say if its on just the one channel or all of your station channels. So there needs to be more analysis of your situation prior to a positive answer being provided....
Sorry I can be of more help...
From YUBEUT...
Nov 10, 2007 | GE 31GT660 TV
Mitsubishi WD-65733 65" HDTV Logo
14 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
