Question about JBL EON 15-G2 Powered DJ Speaker With EQ Speaker
Why do the horns keep blowing - JBL EON 15-G2 Powered DJ Speaker With EQ Speaker
Body control module on 2005 f350 6.0l diesel. Horn keeps blowing
This is no BCM problem this is an steering wheel airbag problem the cover is warped and this causes the horn to honk like you are pressing it.
Oct 30, 2016 | Ford F-350 Cars & Trucks
Why horn keeps blowing on 1986 porsche 911?
hi there
The horn is blowing while you turn your steering wheel ,correct?
when you took of the horn button it was still blowing?Do you have an alarm from factory on the car?
ivan
proporsche@yahoo.com
Sep 09, 2014 | 1986 Porsche 911
Fuse keeps blowing when I honk the horn. 2011 Mitsubishi Galant SE
Try disconnecting the horn and see if the fuse still blows when you press the horn button. If it does not blow the horn is probably bad. Buy a new horn.
May 10, 2014 | Mitsubishi Galant Cars & Trucks
For 2004 ford truck f150 extended cab, I found the horn fuse, where is the horn relay?
disconnect the horn or horns, operate the horn and see if the fuse still blows. if the fuse still blows then there is most likely a short in the wiring. relays rarely cause shorts. if the fuse doesnt blow with the horn disconnected, reconnect the horn and operate the horn again, if the fuse blows you have a shorted horn.
Jul 14, 2012 | 2004 Ford F150
Horn stays on
Normally there is a horn relay, try replacing that. The contacts can weld together and keep the horn on. If you take the relay out and leave it out, you won't have a horn but at least it won't be blowing all the time.
Feb 05, 2012 | 2004 Ford Expedition
Horn keeps blowing. Need to get repaired
try swapping a relay from ? the a/c or something see if it stops, then if not it could be the horn pad it or wiring is shorted
Mar 23, 2010 | 2002 Mitsubishi Montero Sport
2008 Ford Escape Horn fuse keeps blowing after replacing alternator. Horn sounds once then the fuse blows. Also radio and song info that displays in the dash console with the compass does not work... The...
I would trace the wire from the horn and see if it was inadvertently damaged when the alternator was installed. If you have a voltmeter, you can remove the horn fuse and check to see if there is continuity between the horn (non hot side) of the fuse and the car body. This would indicate a short in the wire running from the fuse box to the horn. You can also look around the alternator mounting area to see if any wires are being pinched. Hope this helps. Good luck!
Mar 10, 2010 | 2008 Ford Escape
The fuse for the horn keeps blowing. Any reason
Most common problem is the ground that the horn connects to wit the bolt is rusted and causes it to pull to much amperage so clean the contact first then if it still blows the fuse then the horn relay or the horn may be going bad.over time the horn gets junk in it and causes the coil to overheat and causes it to burn out. Horns cost $15.00 for a new horn and are easy to change. I doubt the relay is bad but it is always possible.
Feb 05, 2010 | 2003 Chevrolet Suburban 1500
Horn keeps blowing steadily without touching horn button area
The horn pad is most likely sun warped, ther is no other reason I know of, and yes it will be very expensive if you have an airbag.
Sep 22, 2008 | 2003 Oldsmobile Alero
Horn keeps blowing
there should be a relay box under the hood you will see the horn relay pull this out
Sep 03, 2008 | 1997 Buick LeSabre
JBL EON 15-G2 Powered DJ Speaker With EQ Speaker Logo
44 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
