Question about Toastmaster (TMHP2) Electric Kettle
Toastmaster kettle switch broken - Toastmaster (TMHP2) Electric Kettle
Filter for salton kettle
The filter for a Melitta MEK17W or Toastmaster TEK17W (identical kettles)are the same.
If you still have the old original filter, here is the link to an inexpensive and permanent repair option using stainless mesh:
www.fixya.com/answer/answerpageslideview.aspx?thid=10641367&ctg=163&lst=1#answer-section
Apr 07, 2014 | Salton Melitta MEK17W Electric Kettle
Switch on Toastmaster stick blender model 1740 is broken.
Superglue a small tab of cut from an aluminum sheet to the the broken plastic tab. Drill a small hole in the aluminum tab to grab the protrusion in switch housing.
Apr 05, 2014 | Toastmaster 2 Speed Stick Mixer
Kettle switch does not go up
If the switch is broken, you might find a repairer to fix it. But dont try any other way because of danger of shock. The kettle are very cheap these days , buy a new one.
Dec 04, 2013 | Hamilton Beach Kitchen Appliances - Others
On/off switch is BROKEN,HOW CAN I TURN THE KETTLE
Hanif, buy a new one because it will be difficult to find replacement and may even be costly. Kettles are cheap.
Oct 23, 2013 | Hamilton Beach 40870 Electric Kettle
Why does the metal in the bottom of the kettle turn green
Your water may have copper in it (or the heating element). When you boil the water you are left with the residue just like you are left with the lime scale. Vinegar should be able to remove both types of stains.
Jun 17, 2010 | Toastmaster (TMHP2) Electric Kettle
Melitta MEK17W Electric Kettle: The little filter that fits into the spout disinte...
Call 1-800-233-9054 and ask Salton/Toastmaster for part number 31036 for the MEK17W kettle. You may as well buy 2.
When this scale filter in the spout of a Melitta MEK17W or Toastmaster TEK17W (identical kettles) gets torn the kettle does not hold in enough steam to trigger the auto off switch. Same thing happens if you do not fully close the kettle lid. With a new and spare scale filter you will get way more life out of this inexpensive and handy kettle.
If you still have the old original filter, here is an inexpensive and permanent repair option using stainless mesh:
May 06, 2010 | Salton Melitta MEK17W Electric Kettle
The spout filter in my Toastmaster TEK17W kettle has torn. Where can I get a replacement
Aug 13, 2009 | Toastmaster (TMHP2) Electric Kettle
Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
Feb 07, 2009 | Breville Kitchen Appliances - Others
Toastmaster (TMHP2) Electric Kettle Logo
24 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
troup
Level 1 Expert
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
