Question about Magnavox MDR513H/F7 Player
Mdr513h/f7 will not stay on keeps flashing,,fan keeps starting and stopping
When fan tries to start dvd tries to spin but stops,,,hear clicking in hard drive fan don't seem to run at full speed
My asko D5155 stops washing and flashes F7
LED L1+ L2/Fault code F7, Pumping out fault (machines with
pressure sensor)
Water not evacuated after 120 seconds pumping out. Program
interrupted.
Check: Drain pump, hoses, installation of drain hose, control unit and wiring.
Dado
Oct 06, 2015 | Asko Dishwashers
Coils keeps icing over
there is a disk that is attached to your coil, it controls the defrost timer in your fridge. that might be a problem or you might need a new defrost timer. hope this helps put you on the right track
Feb 10, 2013 | Amana 25.8 cu. ft. Side-by-Side...
Computer will start up but screen will stay blank
do you get a 'NO Signal' display on monitor, or anything when booting?
if not check to see if you can see lights on inside the frame? if not, do you hear fan spinning or beeping? sometimes the fan on the heat sink over the processor will stop spinning. the chip needs cooling so if fan won't spin an error will not let pc boot up to save it from getting too hot.
if you can take frame off and find the processor chip on motherboard to see if it is spinning. if not that would stop it from booting. if it is spinning then it is something else like the graphics card failure.
Dec 17, 2012 | Gateway One ZX4800-07 20 inch All in One...
Dvd disc incompability
Then just use +r or +/- r. You DVD player is not compatible with +r
Jan 13, 2012 | Magnavox MDR513H/F7 Player
Panasonic PT-50LC14 HDTV went caput and stopped working
Ur tv LED light indicator "LAMP"flashes?Then the projection bulb life is over must be change.This tv been watching the tv at least 4 or 5 hours a day,the last 3 years?The projection bulb only last about 1500 hours.
May 26, 2010 | Panasonic PT-50LC14 50" Rear Projection...
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
Fan stops
The cooling fan for the condenser is probably running, getting hot and seizing up. Check to see if the fan is free spinning after it stops. Take a probe and try to spin it manually. If it turns freely, then it could be going bad with it's electrical windings, the internal coils that create the magnetic field that spins the rotor of the fan motor. I suspect it is seizing up, however, once a fan seizes up, it usually stays that way and won't spin even after it cools down. It could be a capacitor that is going bad and not starting the fan after it gets hot. A capacitor is a small round shaped can type with usually 2 wires hooked in series with the motor it is trying to start. That is what it does, help start the device (compressor or fan motor). Good luck.Ken from Henderson NV.
May 30, 2009 | Dometic Rooftop RV Air Conditioner
Insert dvd, starts to spin up and stops, starts, stops, starts......and then is silent
I have the same problem. when i put in a disc while holding down the little button that makes it think it's closed, it starts to spin and if i keep on spinning it it will say loading until i stop spinning it, then it just says no disc.
Jul 16, 2008 | Televison & Video
DVD player problem
you allneed to make sure the disc is spinning in the player you should hear it whirr as ut builds speed listen closely to it and keep a hand on it to feel when the disk quits if it starts. its supposed to spin v ery fast do you think you could tell by the sound of it if its spinning fast. some times they make a clicking noise because the drive mounts have slid down in the case and allows the disk to rub or tap the case. please let me know what you find out. this is for all three problems. let me know the results so i can further advise you.
Nov 26, 2007 | Cyberhome CH-DVD 300 DVD Player
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Open Questions:
See all Magnavox MDR513H/F7 Player Questions
Magnavox MDR513H/F7 Player Logo
41 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
