Question about DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker
The coffee wont come out except in minor drips
I descaled, it came out in drips. Then I soaked the diffuser for several hours in water. Still only in drips. Then I soaked the difuser in descaler and then rinsed in water...still only drips. Then in straight vinegar and rinsed with water. Still only drips out. The spout is not clogged, those have been cleaned out... and the rinse function produces only drips as well. We have high calcium deposits, but again, I have descaled the machine. What else can be wrong?
EwingElect
  • 276 Answers
SOURCE: Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to http://www.delonghi.com/
Posted on May 24, 2010
#1 Taper
  • 1040 Answers
SOURCE: Delonghi Magnifica Rapid Cappuccino machine has
Your problem is the holes in the cappuccino maker and
steam nozzle are clogged. Clean the holes in the cappuccino maker and the steam nozzle.
IMPORTANT: Before cleaning the holes in the steam nozzle, make sure that there that it is not hot and there is no pressure on the machine.
I'm sending you a free pdf manual download of what I believe to be your machine. If this is not it, give me the model # and I will try to find it.
Good Luck!
Jim
Posted on Oct 01, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: I have descaled and cleaned
Sorry to read about your problem, I hope this helps you out.
run some more fresh water thru the unit
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 23, 2010
mnwarfield10
  • 452 Answers
SOURCE: Lost the instructions / booklet
fill water right to line ... turn unit on ....when its ready to use push and hold the descale button for approx 5 secs the lights wer cups are should stay on.... now place descaler in water ......put a larg container under steam pipe..... turn vaule open fully... it will run for approx 10 secs then stop for at least 15 min...until water runs out ... when light for water comes on fill tank up again with clean water place back into machine and it will flush through until empty .... when light for water comes on again ..job done ..turn vaulve to shut. ///
Posted on Feb 28, 2011
SOURCE: There is a flashing warning
Mostly it is just a very unreliable product. I am on my 3rd replacement after only 14 months.
Posted on May 24, 2011
My Solis Master 5000 will not make a cup of coffee anymore. I already descaled, the water comes through the steam arm, but not through the coffee drip. How to fix?
If the problem is that water come from steam arm only,and if you try to make coffe is nothing happen- try to make several coffees with descaler liquid in the water tank.
Aug 31, 2017 | Solis Coffee Makers & Espresso Machines
Tip
Bosch tassimo T65 - water draining in to drip tray possible cause and resolution
I had a problem on my Tassimo T65 where water was entering the bottom drip tray through the small hole at the rear. It seems many people have this problem but after researching on line there is little help although I found on this sit how to take the coffee maker apart and from that thread the possible cause for my own issue.
So if your machine seems to be leaking from the small drain hole to the rear of the drip tray try this before you think it is either in need of specialist repair by Bosch at a cost almost the same as a new machine or before you start to take it apart and have a look yourself.
CAUSE - The water is coming from the drain hole because the pressure valve at the top of the machine is blocked with calcium deposits through prolonged use without descaling sufficiently.
SOLUTION - Purchase a good quality coffee machine descaler. Sit the whole coffee machine in a tray or large oven tray so you can collect the overflowing descaler throughout the process, it's not economical to waste this solution. Remember to clean down and dry the coffee maker each time.
Use at least half strength descaler do not water it down more than 1:1
Follow the descaling process by inserting the yellow disc and holding the start button down for 3 seconds.
Repeat this process several times, recovering the fluid leaking in to the tray and cup or container. If you start to see small lumps being dispelled in to the cup try to remove these for further descaling.
After several cycles you should notice that the leaking or flow of water from the bottom drain hole becomes less until it stops. To force the dissolving scale out of the pressure valve try running the normal clean cycle but with the descaling solution, the flow is longer and will help flush the restriction.
After a number of descaling and clean cycles the leak or flow from the drain hole will have stopped, if not continue till it does.
Note: I ran cycles for about 2 hours with periods of rest to allow the solution to do its work.
Now the leak or flow has stopped clean out the reservoir and replace with clean water and run at least 4 clean and rinse cycles.
i hope this works for you and now enjoy your coffee.
on Jul 02, 2014 | Bosch Coffee Makers & Espresso Machines
The water in my Nespresso does not come through the from where the pod is, but fill the drip tray! what is wrong?
I had a coffee machine that was letting out the water instead of making the coffee it turned out the hose that leads the water was disconnected from the source if you can get to the hose you may find the problem good luck
Jan 03, 2015 | Nespresso Coffee Makers & Espresso...
CWTF15 WILL NOT STOP WATER FLOW WHEN POT IS MADE.
The coffee dispensing valve is stuck open. It may be due to Calcium deposits.
Descale the machine or manually clean the dispensing valve and the diffuser disc that unscrews to be removed. This diffuser is visible just above the coffee pot.
Oct 16, 2014 | Bunn CWTF15
What is de-scale?
Descaling removes the deposits left behind from hard water. These mineral deposits will slow heat transfer if not removed from the heating element. To descale the coffee maker, use 48 oz of undiluted vinegar (household strength) and have a large ceramic mug to hold the output. Empty any water in the reservoir. Pour vinegar into the Water Reservoir and fill to the top of edge of the clear viewing area. Place a mug in the drip tray and press the Large Cup Button. (Do not use a K-cup.) When the brew cycle finishes, pour the contents of the mug into the sink.
Repeat the brew cycle until the reservoir is empty. Open and close the lid between cycles. When the reservoir empty, fill with water and let the coffee maker stand for 4 hours with the unit ON. After four hours, rinse the coffee maker by doing several brewing cycles (again without a K-cup). Discard the liquid after each brew cycle and repeat until the reservoir is empty.
You may need to perform additional brew cycles if you notice a residual taste.
For more information, including a pdf with the directions for descaling of the coffee maker, see http://www.keurig.com/customer-service/brewer-registration-and-support/frequently-asked-questions .
I hope this helps.
Oct 21, 2010 | Keurig B50 Coffee Maker
B60 special edition clear water surge last couple ounces
Have you tried Descaling? In the manual, it recommends Descaling every 2-3 months, even though you mentioned that you've had yours only 1 month. Worth a try, anyway.
I know they carry a water filter thru Keurig.com for less than $18 that you install right on the water pump in the water reservoir if you live in an area where the mineral deposits are heavy. It lasts 2 months and you can buy 6 replacement cartridges for $25. I just put one in mine today and it took less than 6 minutes to install (5 of those minutes were spent just soaking it in clean water).
If that doesn't help, you can call their Support Team @ #1-866-901-2739 between 7AM-12 Midnight EST. Make sure you have the serial # of your machine before calling. It's located either behind the drip tray (just pull it out) or on the bottom of the unit.
Jan 25, 2009 | Keurig Special Edition B60 Coffee Maker
How do you descale the keurig B40
use descaling product not vinegar ,vinegar remove calcium in little piece descaler melt calcium 1 part descaler 1 part water fill water container start machine for a few second turn off let it seat for 15 minute repeat untill empty to reset the lightnormally its maneer of pressing the on button
i get back to you on that one pierre
Feb 24, 2008 | Keurig Elite B40 Coffee Maker
DeLonghi Perfecta ESAM5500 Fully Automatic Bean to Cup Coffee Maker Logo
143 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
