Question about Boating
I have a v-70 plow the left wing leaks off. the pump the valve and the cylinders have all been replaced and it still does the same thing.i have also noticed that when you raise or angle the plow other functions will jump.
tepfy
  • 319 Answers
SOURCE: steering
ok, if your a do it your selfer, her you go. http://www.stangerssite.com/Optimum/index.html
this link will take you to where you need to go. specificaly for you. You can send them your old parts and they will rebuild them for you at a modest price. The great thing about a company like this is they want your buisness, so advice and where is this and how do I get this off and put it back on is usualy free. You take the part off send it to them, they send it back to you. Everyone knows rebuilt parts are usualy better than bran new parts. Pluss we help out the American economy. Win win.
Posted on Aug 31, 2008
  • 89 Answers
SOURCE: western snow plow will only angle to the right .
IVE NEVER WORKED ON A SNOWPLOW BUT NOONE ELSE IS OFFERING ANY HELP. IT SOUNDS LIKE FLUID IS LEAKING BY THE VALVE AND PRESSURIZING THE LEFT SIDE ALL THE TIME. IT ALSO COULD BE YOUR NO-SPILL COUPLERS CLOGGED OR NOT OPENING FULLY PREVENTING FLOW OF FLUID ON THE LEFT SIDE. GOOD LUCK. JODY
Posted on Apr 07, 2009
  • 832 Answers
SOURCE: western snow plow when you try to angle to right
This is a control valve problem. From you comment, it is
clear that the control valve flows to one direction only.
Please check the control valve of the snow plow that
execute the angle to right or angle to left. Also check
the pipelines before and after the valve. It must have a
free flow of the fluid.
Posted on Dec 02, 2009
  • 2468 Answers
SOURCE: I changed the hoses on my western sonw plow today
off the (joy-stick) in the cab, can you hear the hydraulic motor run when it's set to move to the left???,if so when you changed hoses,did you have all plow angles and heights "centered" when you did this? you may still have a lack of hydralic fluid to that position,does it try to move that way (jittery)?if so, again check for an air pocket in this line and re-bleed the system,overtime it will work itself out of the lines,but you may have it trapped in this hose run
Posted on Feb 07, 2010
SOURCE: fisher minute mount goes up and left and locks up
check your connections, especially the main power plug in, i have used a small "c" clamp over the connection to aid in the same problem
Posted on Nov 13, 2010
Wings are soft and have fliud comming out of top of vent on mvp 3 snow plow
Wings are soft???
Did you overfill the reservoir causing the fluid leakage? Fill with cylinders in the closed position
Dec 24, 2017 | Garden
Western plow will not go left
There is a hydraulic block/valve. Replace it.
Jan 03, 2017 | Cars & Trucks
Plow lifts great when cold gets weaker and weaker as it warms up. could it be as simple as the fluid is to thin?
  • Oil viscosity is dropping as oil warms up. Check that plow stays in up position. If plow creeps down than a leak by the piston seal or manifold valve is likely.
  • Check for contamination in tank. Suspect pump has worn and is loosing pump efficiency. Metal particles in tank are an indication pump is failing.
  • There may be a repair kit available. Make sure that system is completely clean.
  • Only use pump manufactures recommended fluid.
  • Install a pressure gauge on pump.
  • There is a pressure relief valve in the system. Ck if contamination is holding it open or spring/valve seal is bad.
Dec 07, 2015 | Cars & Trucks
I have a 93 chevy with a western unimount. was plowing and now the motor runs,but wont lift or angle. possibly something sheared off in the pump? fluid is full,and no visible leaks.
If you have a Western Plow ISARMATIC pump, a very common problem is ice forming on your pump pickup screen. This will cause intermittent up/down AND left/right functions. Western recommends the fluid be changed annually and I agree. Here's what it looks like after dirt and moisture form on the pump screen. Thats an ice chunk below the screen that appears to be a hump in the case. Be sure to verify that the pump motor is actually spinning before you suspect the pump screen. b7cfa544-07c8-441e-a344-3d5d97b0b2b0.jpg
Mar 08, 2011 | Chevrolet 1500 Cars & Trucks
My snow plow keeps lowering to the ground after i
You have a hydraulic valve leaking in the pump.
Jan 28, 2010 | 1991 Chevrolet S-10 Blazer
Western snow plow when you try to angle to right it goes up does same thing if you try to angle left
Oct 30, 2009 | Plumbing
Craftsman compressor will not come up to pressure
Don"t worry, even the best techs overlook a thing or two during repairs. Lets go over some basics to determine where fault is located. You will need to do some simple tests. If there are leaks the compressor may not reach set pressure. I use soapy water on all connections and on the head/headvalve while compressor is running. Make repairs as necessary. If still low pressure, while compressor is running and has reached max obtainable pressure (still low 70 - 80 lbs), carefully place finger over intake port hole (remove filter). If the compressor is pumping normally but leaking there will be ample suction at intake and cause the compressor to speed-up when intake is obstructed with finger. If you feel plenty of suction and no visible (soapy water) leaks, then the problem is probably the cylinder /ring is not correctly seating and air is leaking past cylinder. Make sure that the cylinder /piston ring is properly alighed and that the lip on the vinyl ring is up toward the head. If you do not feel suction but rather air seeming blowing out of the intake, then the problem is the headvalve plate/reed valves are leaking. The reeds must seal perfectly on their seats and not bent or have obstruction. Replace as necessary. Only one other thing to check and that is the intank check valve. Easy to check. Run compressor till you have about 70 lbs in the tank then unplug compressor. Carefully loosen the inlet hose at checkvalve and listen for air leaking out of tank. If leaking replace checkvalve. Use caution when removing head to try and save the gaskets. Good luck on your repair and email if you have other question.
Apr 21, 2009 | Air Tools & Compressors
Boating Logo
112 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
