My hotpoint aqualtis aqgd 169s main spindle has broke I need to fine a way of getting a replacement
2 Suggested Answers
  • 3 Answers
SOURCE: manuals for a hotpoint aqualts AQGD 169S
Here it is: http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/aqgd169s-19506316701_UK.pdf
Posted on Jul 10, 2009
My Aqualtis AQGD 169 S keeps tripping the mains switch
Make sure you are on a dedicated circuit for this machine and that it is a 50 amp circuit. After that you may have a bad breaker switch which is pretty easy to fix. You also cannot rule out that one of your components went bad on your washer.
Feb 28, 2015 | Washing Machines
Hotpoint aqualtis aqgd169s
It seems most likely shorted somewhere in the wiring system and you have to check for every defective part ,use step by step method
Dec 10, 2013 | AEG Washing Machines
Aqualtis AQGD 169S wont fast spin drum rotates but washing is soaking wet
You need to check the drive, check for belt slippage or if there is a gear drive on the gear box. Also if the capacitor is faulty the motor RPM can go slow. So attach a capacitor in parallel to the one in use and see if there is a change of speed. Also if there is high speed spinning then the motor winding and the controller output for the spin must contact. So check the motor on a test bench to confirm, if not the motor is faulty.
Manually check the movement of the agitator as it must be free and not jammed. If so use some degreasing spray to free the motion for a better spin.
Sep 16, 2011 | Washing Machines
A hotpoint aqualtis aqxx149pm spinning loudly
Hi, This is a common problem with the hotpoint range. It will be the main wash bearings that have failed and need replacing. This is a very easy process but is quite time consuming. Remember tho change everything that is; Bearings, and bearing spider and front tub seal as you dont want to have to do it again in a short time or have leaks coming from the front.
Good luck and get back to me if you need any further help....................
Jan 02, 2009 | Washing Machines
On a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
Nov 19, 2008 | Hotpoint WMA35 Front Load Washer
Aqualtis AQGD 169 S F12 problem Please help :-(
ok, I have just had the 'blocked pump message and after much playing around I have solved it.
Pull the machine out and take the drain out and place in a bucket. Then tilt the machine on its side about 30 to 45 degrees so you can get a hand underneath. At the front there is a black rubber pipe-squeeze this a few times and then run the machine on a pump cycle. Put water in machine (i used a bucket) and repeat. You should get the foul smelling gunk out of the pump. I did this about 4 times and finally the water comes out clean and you should be ok.
Regards and good luck,
Matt
Jul 01, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
