Question about GE Profile Spectra JBP95 Electric Kitchen Range
Oven element stays on when in off position - GE Profile Spectra JBP95 Electric Kitchen Range
Ge oven will not turn off after replacing element
If the element stays on even when the control is shut off it is most likely that the contacts are welded together in the control. This usually happens when the element blows out with a big bang. If this is the case the control will need replacing.
Feb 16, 2014 | Ovens
Hi there, We have a Fidigaire Gallery electric stove and the oven does not heat up. We press thej"Bake" button followed by the up arrow to set the tempurature but the oven will not heat up. The...
well... have a volt meter?
Are the bake and broil coils the same?
If so, you can swap them to see if the broiler element glows in the bake position... if so then the element is NFG... to proove that put the bake element in the broil position and fire up the briol function... it should not heat up...
Usually the MFG. intentionally makes the elements with a different offset, so you cannot mix them up...
that's what the meter is for... unplug the element, and put the probes in the socket.
You will be reading 220 Volts, so be XTRA careful... if no 220 then the Module that controls the relay to activate the element connector is not working correctly... so you have to sorts test both ways...
Just be careful...
Mar 10, 2011 | Ovens
The "element on" indicator light
It the indicator light on all the time? Or after cooking and you turn the elements off the light stays on for a long time but it does eventually go off?
Mar 04, 2011 | Ovens
Bottom oven element stays hot will not cut off
In order for the element to stay on, the oven switch must be broken. No details are provided, but if your oven is like most, you have an Oven Selector knob for ~bake, broil, clean and another knob for Temperature selection.
Look at your Oven Selector knob closely to make sure it is not slipping on the shaft. It may be as simple as the knob being broken, and even though you are turning it to the Off position, the switch may still be on. If the knob is indeed turning the switch shaft, then it is most likely the switch stuck in the own position. Thanks for using FixYa.
Mar 03, 2011 | Ovens
When oven is in on postion oven element does not come on but broil element does;when in broil position nothing happens and indicator light is dim when in off position but burns bright when in oven...
sounds like you have a bad control board.or you have crossed the broil element wire witha bake element wire.these are the first things to check
Jan 22, 2010 | Microwave Ovens
Thermastat or element ?
Could be both parts are faulty from symptoms you describe.
The indicator light should not be on if it is in the off position, this would suggest the thermostat is faulty.
On the other hand, if the element is faulty, then obviously, there will be no heat
To be certain if the element is faulty or not, then you need to test the element with a meter.
Jan 20, 2010 | Baumatic B180 Electric Single Oven
Beaumatic B151SS Single Oven Problem
Disconnect the element, and run the oven for at least 30 mins,,if it does not blow fuse, then more than likely it is a faulty element.
What I cannot understand is that you say the thermostat light is on after the fues has blown? I would have thought that the light would be not be on, if the fuse has blown.
If after replacing fuse and the stat is in the off position, and the indicator light is on then indeed the stat is faulty.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Baumatic B151 Electric Single Oven
Oven will not shut off broiler element stays on
The control knob more than likely operates a relay that has gotten stuck in the energized position. If this isn't the case then the Temp sensor or thermostat probably shorted internally. Unplug the unit before attempting any work.
Nov 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Problem with oven
In order for the element to stay on when the control is turned off either the control has shorted or the contact that the control switch controls has shorted, if the the light goes off as usual it is most likely the contacts in the elements relay that have welded themselves in the closed position but both the switch and relay will need to be tested.
Mar 03, 2008 | Frigidaire FEF366DC Electric Kitchen Range
Oven heating element stays on
If element stays on even with oven turned off you probably have a bad main board. A relay on board is probably stuck on. If it stays on, but at a reduced heat...not getting red hot, it may be from a shorted wire causing 110 volts to get to element.
Nov 02, 2007 | GE Profile JTP18 Electric Single Oven
GE Profile Spectra JBP95 Electric Kitchen Range Logo
16 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
