All Manuals are available on Frymasters website. the orifice is located in the pilot line where the gas line connects to the pilot. You will have to unscrew the fitting and remove the orifice. It is best to clean the entire pilot assembly and the gas line going to the orifice. Many times when a pilot tube has leaked and possibly burned incorrectly, the gas line can fill up with suit. Your clogged orifice could recur if the line is not cleaned as well. I have had to return to customers locations only to find an orifice I cleaned was clogged again. I then removed the pilot feed line, when I blew through is it filled my hand with black suit. It can be a messy and frustrating job to pull all this apart. You may want a professional. Be sure you have no gas leaks upon completion, use soap bubbles to check for leaks!
Click here to download manual from frymaster
