What are the three r3 of the 3qr method - Office Equipment & Supplies
HOW DO I RESET MY BLACKBERRY 9770 BOLD BACK TO DEFAULT FACTORY SETTINGS
To reset the Blackberry Bold 9000 / 9700 with three methods. In the first method you hold down the Alt key, the Caps lock key and hit Delete. Your Blackberry will start resetting. This process will take about 2 minutes to complete. The second method is the double reset. Hold down the Alt key, the Caps lock key and hit Delete twice. This method is helpful if your Blackberry is frozen. The third method is called the battery pull method. Remove the battery and keep it out for about 30 seconds and then put it back and power on. It will reset in 2 to 3 minutes. You resort to this method if the first two methods don't work.
Nov 05, 2014 | Cell Phones
Vista pack 1,2 and 3
As I am not 100% sure as to what you are asking about, I am going to direct you to the Microsoft website that helps you obtain the latest Windows Vista Service Pack. The link is:
http://support.microsoft.com/kb/935791
It give you three different methods to obtain them. Method one is turning on automatic updates. Method two is checking for possible updates on Windows Updates, and Method three is personally obtaining the updates from the Microsoft Download Center. Hope this helps!
Sep 16, 2011 | ASUS Computers & Internet
My nokia n73 show the memory full ,when i reset my mobile and i enter defualt password 12345 then it does not accepted
use three finger method to reset your phone
follow this step :
Turns off the phone
Press simultaneously on the green/talk, 3 and* keys and hold the 3 keys.
Turn on your phone
Wait for the onscreen Format message then can release the three keys
This method may also work for Nokia phones that won't turn on.
Note that before making a reset on Nokia's latest phone
using the *#7370# or the 3 finger method, better make a backup, as you will automatically delete important data:
The license for pre-loaded contents (music, video, maps,etc..)
Mar 24, 2011 | Nokia N73 Cellular Phone
Could you please let me know how can i reformat my nokia n72
press *#7370# and insert 12345 as phone code
or use three finger method, follow this step :
Turns off the phone
Turn on your phone
Note : that before making a reset on Nokia's latest phone
Mar 22, 2011 | Nokia N72 Cellular Phone
I TRY TO RESET MY PHONE BUT I FORGOT MY SECURITY CODE
you can use three finger method
follow this instruction to format your phone
Turns off the phone
Turn on your phone
Mar 05, 2011 | Nokia N73 Cellular Phone
How to format nokia 6233?
dial *#7370# and insert 12345 as phone code
Turns off the phone
Turn on your phone
The license for pre-loaded contents (music, video, maps,etc..) and pre-installed application (N-gage).
Feb 19, 2011 | Nokia Lands Phones
Ive lost my password and i cannot log on how do i reformat my toshiba laptop with windows 7 preinstalled
Hey, Here are three methods for you to reset Windows 7 password.
Method one: Logging in Windows 7 with an available adminaccount to recover Win 7 password
Methods two: Creating a password reset disk to recover the Win 7 password, bythis methods, you need create a Windows password reset disk before you havelost or forgotten your Windows admin password.
Method three: Using Windows Password Recovery Basic software to recover Windows 7password.
Nov 14, 2010 | Toshiba Satellite L500 Series Notebook
My phone will not start up. Please help.
remove memory card and battery of your cell phone for 30 mins then put your battery back and turn on your phone if its not work then you must format your phone by three keys method
Sep 04, 2010 | Nokia E63 Cell Phone
Sanyo TV I need a code for my optimum cable remote control to turn on and off the TV with their remote control.
Here's the instructions and codes plus an alternative method if one of the codes below do not work.
Three-Digit Code Programming Method:
  1. Turn on the TV.
  2. Press and hold the TV and DONE buttons simultaneously for 3 seconds. The iO button will light.
  3. With the iO button lit, point the remote at the TV and enter the TV's three-digit code (see code table below). The TV will shut off when the correct code is entered.
  4. Verify by pressing the SEL button. This should turn the TV on and off.
  5. Press the TV button to store the three-digit code. The iO button will blink twice to confirm that the code is stored.
Codes: 007, 053, 057, 082, 020, 239
Auto Search Programming Method Use this method if the three-digit code method does not successfully program your remote control:
  1. Turn on the TV.
  2. Press the CBL and DONE buttons simultaneously for 3 seconds. The iO button will light.
  3. Hold down CH+ and release it as soon as the TV powers off.
  4. Press CH- five times (the television may or may not turn on again as you do this). If the television does not power, turn it on manually before proceeding.
  5. Press CH+ one at a time until the television shuts off.
  6. Press TV to save the code.
To save time, the Auto-Scan function is trying codes as fast as possible while CH+ is being held down. It scans so fast that you may pass the desired code while holding down the CH+ button. Steps 4-5 allow you fine tune the auto-scan so you reach the correct code.
Nov 26, 2009 | Sanyo Televison & Video
How to format the n72
Hi! Please Note that the following Nokia Phone Formatting methods will erase all your Phone data. So do backup before proceeding for Formatting. However, you can format your Nokia N72 in the following three methods-- Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Nokia phone. 2. Hold down the following three keys, Green (call answer button) * Key, and Number ?3? key. 3. While holding these buttons, press the power button and switch on the phone. 4. Wait for message ?Formatting? to appear on the screen and release all keys once you see that message. Method 2: Hard Format of Nokia Mobile Phone 1. Switch off your Nokia phone 2. Now Press following key sequence *#7370# 3. Enter Default lock code is 12345. 4. While holding these buttons, press the power button and switch on the phone. 5. Wait for message ?Formatting? to appear on the screen and release all keys once you see that message. Method 3: Soft Reset of Nokia Mobile Phone 1. Switch off your Nokia phone 2. Now Press following key sequence *#7780# 3. Enter Default lock code is 12345. 4. While holding these buttons, press the power button and switch on the phone. 5. Wait for message ?Formatting? to appear on the screen and release all keys once you see that message. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Jun 06, 2009 | Nokia N72 Cellular Phone
15 people viewed this question
jasbo
jasbo
