Question about Precor EFX 556i Elliptical Cordless
Pause not working on efx 556i
When I stop pedaling it does not go into pause mode
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
If it immediatly goes blank, then the battery may be low and need to be replaced.
Posted on Jan 01, 2015
My precor efx 546 makes noise like a squeaking in left pedal it seems I tried to tighten pedal but I the whole bolt and screw turn together and the other pedal makes no noise
This squeak is normally caused by a bad bearing in the wheel. In order to provide you with the correct wheel, I will need your serial number. The following link will take you to our Precor EFX 546 page.
Repair Parts for Precor EFX 546 Ellipticals SPORTSMITH net
May 29, 2014 | Exercise & Fitness
If I stop moving, I use to have a delay that said pedal faster. This stopped and now shuts off if I stop and I lose my stats. How do I get the delay back ?
Does the elevation work? If not, the battery is probably dead. If the elevation works fine, then it may need to be changed in the settings menu.
Apr 29, 2014 | Precor EFX 576i Experience Series...
Pause not working
These units have a battery that is in the front housing behind the lift motor. Usually when the unit stops pausing when stopped during a workout it means the battery has gone bad. This happens a lot in older units. You can find them at local battery specialty stores or order them through companies like Sportssmith or Fitness repair parts.
Feb 13, 2014 | Precor Efx 556i Experience Series Total...
Pecor 556i says to peddle faster
Then pedal faster.....
If you are pedalling fast enough, the battery may be low.
Jan 11, 2014 | Precor Exercise & Fitness
Loud groan from rear of machine
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Typically this is caused by a bad pillow block bearing. I would suggest trying to pin point the sound a bit better, but this is common of the pillow block bearings.
Precor Parts for EFX 554i 556 556i Ellipticals SPORTSMITH net
Dec 23, 2013 | Precor Exercise & Fitness
Where is the battery located in the 546i
It should be located under the lower electronic board. If you have your serial number, you can go to our Website and get a diagram of your machine. This will show you exactly where your battery is located. Precor Elliptical EFX Repair Parts Belts Wheels Pedals SPORTSMITH net
Mar 21, 2012 | Precor EFX 546i Elliptical Version 4
Precor efx 546 shuts off when I need to reverse direction during a workout also, the sliding is not smooth (very difficult to push the pedals on an easy level)
Procedure 6.4 - Troubleshooting the Generator
The generator performs three functions in the EFX. First, by controlling the amount of electrical
load applied to the generator, the user's pedalling resistance is controlled. Second, the generator
is used to charge the EFX's internal battery. Lastly, one of the generators six phase output
windings is monitored to determine when the unit is in use and when it is idle. This system also
determines the stride rate by determining the operating speed (output frequency) of the
monitored generator winding.
Warning
Because this is a self powered unit, it will either be necessary to either equip the unit with the
optional external power supply or have an assistant pedal on the unit while voltage
measurements are being taken. Because of the danger of working on the unit while it is in motion
using the optional external power supply is strongly recommended.
1. Perform the generator resistance test per Procedure 5.1. If any of the resistance
measurements are significantly high or significantly low, replace the generator.
2. The following voltage reading must be taken while the unit is in motion. Extreme care must
be taken to keep meter leads, hands, etc. clear of all moving parts. Using an AC voltmeter,
measure the voltage between 1 & 3, 2 & 3, 5 & 7 and 6 & 7 on J1 of the lower PCA. All AC
voltage readings will vary depending on the unit's stride rate at the time the measurement is
taken. At a stride rate of 100 strides per minute, all three voltage readings will be
approximately 100 VAC -110 VAC.
3. If any of the six readings in step 2 are significantly low, replace the generator.
Precor Equipment Repair Parts Treadmill Belts Ramp Sleeves SPORTSMITH...
Sep 05, 2011 | Precor EFX 546i Elliptical Version 4
There is a clicking sound periodically coming from the right pedal while I use the machine (Precor 546i). I tried tightening the bolts but the clicking persists. Any thought would be greatly appreciated....
It sounds like it could be a faulty bearing in one of your wheels, a worn ramp or a combination of the two. The following link will take you to our Precor page. Please reference your model and serial number. This will allow you access to the correct parts and manuals for your machine.
Aug 06, 2011 | Precor EFX 546i Elliptical Version 4
Precor EFX 556i Elliptical Cordless Logo
146 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
