I can't get my HP deskjet 3050 to connect to my ASUS RT-N66R wireless router
It just keeps timing out
  • 59 Answers
SOURCE: when i try connecting my
try reinstalling the router then it would ask you for a new network key
Posted on Feb 14, 2011
SOURCE: I'm trying to connect my
Click Start, All Programs, HP, HP Deskjet, Connect a new printer. Choose Network Printer, then connect the USB. It will transfer the wireless settings. Unplug USB. Viola! Wireless works.
Posted on Feb 15, 2011
bvincesf
  • 35 Answers
SOURCE: how ro connect HP printer DESKJET 3050
This model printer does not have a network connection therefore to print via wireless from the laptop, the printer needs to be connected to a computer and setup as a shared printer. This computer must be connected to the wireless router with a LAN cable.
Posted on Jul 04, 2012
jadiazq
  • 2878 Answers
SOURCE: Asus RT-N66R router for wired operation
  1. Plug in your ISP modem to the uplink port on ASUS router.
  2. Plug in your computer to any other port.
30 sec setup - http://youtu.be/fNcPg2lfjVw
Sorry Tom?
Posted on Oct 11, 2012
Geekman
  • 32281 Answers
SOURCE: How to connect the ASUS EA-N66R as a range extender.
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers.
Posted on Mar 09, 2013
Make nat open for rt-n66r
Use portforward dot com. Enter your model and use the instructions.
Jan 26, 2013 | ASUS Rt-n66u Dual-band Wireless-n900...
Rt n53 asus slow wifi
So, If you have internet connection speed problem with your wireless try with the following steps,
1.) Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.
Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.Com before and after following these steps.
Nov 18, 2012 | ASUS Rtn53 - Rt-n53 Wireless Router - Ieee...
Replaced flaky router with new Asus RT N53 Wireless Router Wireless devices work but how do I reconnect static devices?
Hello try downloading the manual from here:
http://www.asus.com/Networks/Wireless_Routers/RTN53/#download
Select your windows
Select manual
And click on global for download
Unzip the file before you can read it.
Good luck
You will need a pdf reader (Adobe)
Nov 12, 2012 | ASUS RT-N53 Dual-Band Multimedia...
Sorry Tom?
Oct 10, 2012 | Computers & Internet
How ro connect HP printer DESKJET 3050
Jul 04, 2012 | Linksys WRT120N Router
My wireless printer hp deskjet 3050 is not printing the wireless blue light keeps blinking and does not go solid like it used to what do i do?
if the wireless blue light is blinking, it means it's not connected to the router or it's not communicating with it.If wireless blue light is solid ,it means it's connected to the network.
you will need to reconnect the printer to the network by using a USB cable.it will configure the wireless connection.
  1. to start the installation ,click on the start button on the computer
  2. click on programs or all programs depending on the operating system on the computer
  3. look for the HP folder and then left-click on it
  4. inside the HP folder,left-click on DESKJET 3050a or DESKJET 3050 series
  5. inside the DESKJET 3050 folder, left-click on product setup and software
  6. left-click on connect a new printer
  7. it will open up a page with options on how to connect the printer
  8. select wireless and then hit next
  9. if you are prompted to connect the usb ,please connect it
  10. if it asks you whether printer is connected to the network,select no
  11. click on next
  12. if usb is already plugged in,tick the box that says it's already plugged in
  13. hit next
  14. wait for the prompt to unplug the cable
  15. try printing wirelessly
let me know if these steps do not solve your problem.
Jul 15, 2011 | HP LaserJet 3050 All-In-One Printer
I'm trying to connect my wireless HP DeskJet 3050 printer with my computer. In the set up it said to Press the WPS button on the router. The product automatically finds the wireless network and configures...
Feb 10, 2011 | Arris SURFboard SBG900 Wireless Router...
Open Questions:
Secure Your Data With Our Online Backup Services ' DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
May 25, 2018 | Quantum Computers & Internet
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
