Question about General Electric Microwave Ovens
Change light bulb
How to change light bulb in ge microware jes1453 model
  • 48 Answers
SOURCE: GE MICROWARE WON,T HEAT UP
Likely problem: Blown magnetron. On microwaves, this can generally go dead, usually with a popping sound. Solution: A: Call an appliance repairman to replace the magnetron in the device, or B: buy a new microwave. Depending on how much you paid for it, you might be getting a better deal on either end.
Posted on Jun 05, 2007
SOURCE: The light inside the microware
1 take the front grill off. 2. you will see a cover with one screw around the area of the light. normally this is right in front.
Posted on May 09, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: I NEED A GLASS TRAY TO FIT MY G.E. MICROWARE MODEL
That is part # WB48X194 and you can get it here for $74.92 (that's compared to $92.50 direct from GE!).
Posted on Jun 24, 2009
freetek
  • 5568 Answers
SOURCE: Have a Whirlpool RMC275PD microwave. Light bulb
If you see no removable panel inside the cavity, it will be necessary to remove the housing to replace the bulb. Because of the nature of microwave energy, the fewer sharp edges and other irregularities in the cavity, the happier the magnetron is since all those have some effect on the distribution of the energy and efficiency of the unit. That's why one should avoid having any larger metallic container in a microwave. Using aluminum foil to prevent the drying out of certain types of foods is permissible because the ratio between moisture content of the food and the reflection of energy caused by the foil is not significant and the energy is mostly absorbed instead of reflected.
Posted on Oct 31, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: GE Spacemaker Micro/Oven Need to change
While replacing the cooktop light can be done by accessing the cover on the bottom of the oven, replacing the cavity light will require you to pull the oven from the wall and remove the outer cover.
The installation instructions are very handy in this case, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Aug 20, 2010
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
Oct 19, 2014 | Microwave Ovens
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
Model JVM1790SK 01 Where/how do you change the
This is a pretty bad design, sometimes you can just remove the upper grill and access the light assy. If the panel is to tight to work in to change the light,you get to take the whole micowave down and remove the outer wrapper to change the light bulb. This is also not a standard bulb (part #WB25X10019). You may be able to get one from Lowes or Home Depot actually Sears would be a better bet, otherwise you will need to order one from an appliance parts outlet. Hope this helps and sorry I didn't design the thing I just fix them.
Jan 24, 2010 | GE Advantium 120 Convection/Microwave Oven
Light bult in a Microwave oven is burned out.
There should be a panel covering the bulb iside the cookspace with a screw holding it on. Remove screw, cover then bulb.
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I NEED A GLASS TRAY TO FIT MY G.E. MICROWARE MODEL JEM31SA 002.
Jun 23, 2009 | Emerson MW8779W Microwave Oven
How do you replace a light bulb in a GE microwave oven model no.Jes1451BJ02?
The first step is to unplug the oven before changing bulbs.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
If that doesn't answer it, please reply back.
Aug 20, 2008 | GE Microwave Ovens
GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 03, 2008 | GE JES1289SK Microwave Oven
May 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Jun 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top General Electric Microwave Ovens Experts
William Miller
William Miller
Tom Chichester
Are you a General Electric Microwave Oven Expert? Answer questions, earn points and help others
