Question about Goodman Manufacturing Gas/Electric Packaged Units
I have a goodman gas/electric package system. It has power but will not turn on heat.
The service light blinks 3 times and quits, then repeats.
    New Friend:
    Problem Solver:
  • 15 Answers
There should be a code chart on the inside of the control panel.
Posted on Oct 12, 2016
1993 goodman status light 4 times blinking
Witch blower is running, the inducer or the systems blower?
System blower could mean the the high limit is opening and shutting down the systems gas train, I would check this out first.
The other problem could be with the pressure switch for the gas train, it is supplied from the inducer motor, check to see if it is operating fully.
HSI boards do go from time to time, this sounds more like a system control problem.
Jan 24, 2008 | Goodman GMS90703BXA Heater
Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Nov 23, 2011 | Goodman Heating & Cooling
I turn the thermastat to heat on my goodman gms90904cxa and the inducer fan does not come on and after a couple of seconds the lights blink 3 times
Hello, a 3 blink pattern indicates a open limit switch. Most of the time a dirty filter, dirty blower wheel, weak blower motor, can cause the limit switch to open.
Oct 02, 2011 | Goodman Heating & Cooling
Goodman gmp0503 unit has status light blinking slowly all the time. The indoor blower wont even come on when you switch from auto to fan on thermastat. The status light says for one blink to check gas...
Take a jumper wire and jump out the R and W terminals on the furnace. The heat should come on. If it does not, you have a bad board. A steady blink indicates no call for heat. You may have either a broken thermostat wire or a bad thermostat if unit fires when you jump it.
Mar 20, 2011 | Goodman Heating & Cooling
I installed a new goodman unit this past spring. It seems to work ok to good in the day time but the tempature is warmer so we do not need as much heat. At night I know the thermostat is coming on. I...
Heating Mode (Goodman Service Manual)
· The furnace control checks for an open main limit (this
limit is normally closed). If the limit is open, the furnace
will remain inoperable until the limit is closed. During
an open limit the circulating air blower will be
energized. The status light will blink four (4) times.
· The room thermostat reacts to a demand for heat.
· The control will then check to insure that the vent
pressure switch is open. If, at this point, the vent
pressure switch is closed the control will blink two (2)
times and will remain inoperable until this situation is
corrected.
· The venter blower is energized.· The vent pressure switch will close when it detects a
pressure in excess of its setting. If the pressure switch
fails to close the status light will flash three (3) times.
The sequence cannot continue until the pressure switch
closes.
· After a pre-purge of about ten (10) seconds the electronic
ignition device will be energized.
· After a slight delay the gas valve will open.
· The burners will ignite and the flame sensor will detect
the presence of flame. The ignition device will
deenergize. If the sensor does not detect the burner
flame, the gas valve will close and the ignition cycle
will be repeated for a total of three attempts. If, after
the third attempt, the presence of flame is not detected,
the furnace will go into a lockout condition for one (1)
hour. It will then repeat the ignition cycle. This one (1)
hour lockout and retry will occur indefinitely.
· Thirty (30) seconds after the main valve is energized
the circulating air blower will be activated.
· The furnace will remain in operation until the demand
for heat is satisfied.
· Once the demand is satisfied the venter will shut off,
and the circulating air blower will shut off after the field
selectable time off is attained.
· The furnace will remain dormant until the next demand
for heat.
Dec 03, 2010 | Goodman GMS80903BNA Heater
Hi. I am not getting any heat. I have a White-Rodgers manual mercury thermostat model 1F56-501 and natural gas heat with GOODMAN packaged gas/electric model PGB024050-1 Before I call a service rep, I...
Hello,Good job with description.Something is keeping the condenser off(saftey).Do you have an emergency heat setting on the therm.It will run electric heat strips only until service can check it out.Very rare that the disconnect switch (black box) is it.Need electrical meter to prove it out.
Dec 01, 2010 | Goodman Heating & Cooling
Have a Goodman GPG13 single package gas-electric heating and cooling unit. Turned on the heat and the outside unit ran a short time then shut off. Smelled gas after it shut off. Is this an igniter...
There is a induced draft motor that will run first to purge the combustion chamber and induce a draft, a pressure switch closes proving an induced draft exists, thus allowing the spark and pilot gas, or hot surface ignitir and gas to pilot rsil and /or burners, a trial period for ignition about 30 seconds each for 3 attempts will be made and if not lit by the 3rd attempt it locks out, requiring a reset of power to unit to reset the module or circuit board etc. 1st see what motors running, is it the flue exhaust motor/induced draft??
Nov 02, 2010 | Goodman Heating & Cooling
Central Heating - Ignitor starts but no gas
Check the flame sensor near the ignitor....it could just be dirty. Check that first. Check the electrical connections to it. Also, check the flame sensor's position. It must be within the correct proximity of the ignitor to tell the gas valve to open. Make sure the gas is on to the unit.
Mar 15, 2009 | Goodman GMS90703BXA Heater
Goodman HVAC Package Unit
Cycling the external switch on the GMS series will not help you. That switch is for A/C only. At the unit found inside the house, remove the front cover. If there is a door switch, tape it closed. Now if the thermostat is calling for heat, the unit will cycle as you mentioned. When the unit does not start, check for a blinking light on the circuit board. After three unsuccessful tries, the light will blink a code (2 blinks then a pause up to 9 blinks than a pause). Make a note of how many blinks you see. On the reverse side of the access panel you will find a diagnostic schematic. It should tell you a fault code corresponding with your blinking. This will give you a starting point where to look. If the codes are not found there, check inside your owner's manual. Or you can call Goodman at 713-861-250.
Get back to us with those codes and maybe we can help you further.
Oct 30, 2007 | Goodman GMS90703BXA Heater
Goodman Manufacturing Gas/Electric Packaged Units Logo
Top Goodman Manufacturing Heating & Cooling Experts
Robbie Daniels
Level 1 Expert
zephyrusd
Level 1 Expert
snowmanii
Are you a Goodman Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
