Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Cant turn off jets - Dream Maker Spas Dream Maker Ez Spa Hot Tub
My intex pump jets won't reset or turn off the heater is on but so are the jets can't get jets to go off unless unplugged then you lose the heat.
Sounds like bad controller?
Do you still have problem?
Use Comment link on this thread, and inform this forum what you may gave done this far?
Did you fix it? Did Intex help? What was problem?
if not...
Support Intex
Dec 23, 2014 | Intex Pool & Spa
How to turn on the jet sprayers on side of our pool?
turn each one of the auxs off one at a time remember which one it is then label it if the pump wont shut off then start turning off breakers until it goes off if you turn the breaker back on and it does the same bad relay
May 12, 2013 | Jandy Pool & Spa
I have a very old city golf, an i fused the engine. We have just put a new engine in but the car wont idol. My mechanic cant seem to find what is wrong? He has said something about the carburetor but cant...
carb ?? oldie for sure and the problem here is your mechanic is no doubt very good but doesnt have the experiance with old stuff ,what you need to do here is take the carb off and a sheet of newspaper on the kitchen table and clean it out paying special attention to the idle adjustment screw on the side ,clean it up then set screw to 1/ half turns out .Now on these carbs looking from the top are two jets that can be removed ,one is the idle jet and the other is the compensating jet ,the other main jet is fixed ,under the compensating jet is another jet as well and what happens is when you take the engine out and turn it over the muck inside the carb moves and it blocks the jets up ,just give it a good clean and it should be fine the CO2 should be set to less than 2% using a calibrating machine but this is only for the test station afterwards set it to optimum where engine sonds right .
Sep 15, 2011 | Volkswagen Golf Cars & Trucks
How many turns should i tweek the jets on the carbs. i have them at two and a quater turns now and it still dosent maintain a steady rpm. and it lacks a power in 1st and 2nd gear. ive tried quater turn...
The screw I think you are adjusting is the idle mixture screw, and will only make a differnce at idle
You set at the smoothest idle
If power in 1 and 2 is the problem, then there is something else, make sure the carb is clean, the exhaust is not blocked , the air filter is clean and relatively new,valve clearances? are ok, new spark plug , new oil, and then start looking at the jetting.
up to 1\4 throttle -pilot jet
around mid range -needle position
top end -main jet.
try riding with and without choke to get some idea, if it runs better with some choke then it is lean
Jun 30, 2011 | kawasaki ZX-6R Ninja Motorcycles
May phone(samsung jet) freezes and i cant turn it off unless i remove the battery and when i open it, it was still freezed
The memory of your phone is full so try and decongest some infromation you think you don't need again in order to create space for the phone
Feb 09, 2011 | Samsung Jet S8000 Cell Phone
Cant get it close enough to start the tiller to adjust it...
set low speed jet to 1 turn, highspeed jet 1and a quarter this should start ya off tweek from there.
Sep 27, 2010 | Mantis Garden
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Cant connect my samsung jet wifi to my home router
Well if you cant connect, you may need to go to your hub setting and check the WEB KEY you can then put this is manually and that should do it, i have a samsung jet and i did it this way and now i can connect every time, hope this helps :D
Aug 01, 2009 | Samsung Jet S8000 Cell Phone
HP 610 C inkjet printer
i have a laptop full of usb ports ,for that i have purchased parallel to usb port to suit to printer and laptop but iam unable to print .laptop is asking drivers
Nov 18, 2007 | HP DeskJet 610c InkJet Printer
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
41 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
