Question about Ruud Heating & Cooling
How many tons is ubhc21j18shc - Ruud Heating & Cooling
Is model #TCGD60S41S3A a 5 ton unit?
Yes. The number immediately following the "TCGD" advises one what the tonnage is. Your Model indicates a "60." So, divide the number by 12.
If the number is 60, it indicates a 5 ton unit
If the number is 54, it indicates a 4.5 ton unit
If the number is 48, it indicates a 4 ton unit
If the number is 42, it indicates a 3.5 ton unit
If the number is 36, it indicates a 3 ton unit
If the number is 30, it indicates a 2.5 ton unit
If the number is 24, it indicates a 2 ton unit
If the number is 18, it indicates a 1.5 ton unit
If the number is 12, it indicates a 1 ton unit
Hope this helped you.
Aug 24, 2014 | Heating & Cooling
How many lbs is a ton
That depends on what you mean by "ton."
A short ton is 2000 lb. A long ton is 2240 lb. A metric ton is about 2205 lb. A ton shortweight is 2240 lb. A ton longweight is 2400 lb.
Jun 14, 2014 | Computers & Internet
How to measure air conditioning tonnage to square feet of hom
Read size of air conditioner you need , each ton of air conditioning will keep cool 400 square.so higher ton yo pick you feel cool.please read below square feet to ton chart.
1 ton on 400 sq. ft.
2 ton on 800 sq. ft.
3 ton on 2000 sq. ft.
5 ton on 2570 sq. ft.
May 28, 2014 | Computers & Internet
How many punds in 1 ton
A short ton is 2000 pounds.
A long ton is 2240 pounds.
A metric ton is about 2205 pounds.
A ton shortweight is 2240 pounds.
A ton longweight is 2400 pounds.
Apr 30, 2014 | GPS
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
Apr 09, 2011 | Heating & Cooling
Need to know how many tons this AC unit is
To find out the tonnage, I would need to see the model number. If you can go to the out door unit and write down the number or look for this in the numbers and letters. There are 12,000 btu's per ton of cooling. I don't know if you have a central unit or a window unit, but look for numbers like this. 018, is a 11/2 ton, 024 a 2 ton, 030 a 21/2 ton, 036 a 3 ton, 042 a 31/2 ton, 048, a 4 ton, they don't make a 41/2 ton, and it go's to 060 a 5 ton. This is the largest for a residential that is made. From there they make units for commercial buildings that start at 71/2 tons up to 350 ton's on 10,000' warehouses for wine storage and so on. This is larger then a train box car. You may want to write this down and keep it as most people have no idea how to tell, and now you do. Please don't forget to rate me as I know you will be kind. Let me know if you need my help for any thing.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Sep 08, 2010 | Heating & Cooling
How many tons is a Goodman Central Air Unit with Model Number CKL30-IE?
That is a 2.5 ton system. The model numbers are as indicated:
24- 2 ton.
30- 2.5 ton.
36- 3 ton.
42- 3.5 ton.
48- 4 ton.
60- 5 ton.
Hope this answers your question!
Jul 15, 2010 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
47 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
