Question about Toshiba Tecra A2 Notebook
Stuk toshiba splash , cant access setup - Toshiba Tecra A2 Notebook
    Problem Solver:
  • 7 Answers
Try Through BIOS at the Start UP ! -
Turn on the Laptop while keeping ESC key pressed !!
Then after the "Beep" hit F2 ..
Posted on Mar 13, 2014
How to set up bios on toshiba laptop tecra m1
Hold down the Esc key and press and hold the power button until the on/off light on the system indicator panel illuminates (green) for approximately one second. When the following message appears on the screen: "Check system, Then press [F1] key," press F1. The System Setup screen appears.
If that doesn't work, try powering on the laptop and when the Toshiba splash screen comes up, hit F2 or F12.
One of these methods will get you in to the BIOS setup.
Mar 10, 2015 | Toshiba Computers & Internet
How to get to toshiba nb205 bios
Jun 10, 2014 | Toshiba NB205-N210 Netbook
Cannot access bios setup
The function key, probably F1 must be pressed as the first splash screen shows otherwise you will miss it.
Mar 21, 2014 | Gateway NE56R Dual Core 2.10GHz 4GB 320GB...
Toshiba laptop will not go psat the toshiba logo
There are a number of stages to go through. For all these please ensure that the laptop is switched off. First, remove the battery, then plug the mains charger lead in and try to boot, if you get past the splash screen than it is the battery at fault, if not then the next step is to switch the laptop off close the lid and turn it over, on the bottom you should see an access door with either one or two screws, open this access panel up and remove the hard drive, turn the laptop back over and try to boot up again, it should go past the splash screen and the detect that there is no hard drive installed, if it dose not get past the splash screen then turn the laptop back over re install the hard drive, try again to boot up, if still no good then try removing one of the memory chips, these are found under the same access panel. Try again if still no go then remove the other memory chip and replace the first one you took out. If no joy after all these steps, then sorry I have no further suggestions. Good luck.
Feb 03, 2014 | Toshiba Tecra R850 Series Black Notebook...
I cant access the BIOS during the boot processon my toshiba satelite l645-s4026
Are you hitting the right key to get into the bios? When you boot the laptop it should tell you what key to hit to get into the BIOS or System Setup.
Mar 25, 2012 | Compaq Computers & Internet
My laptop is not loading anything only it show toshiba logo then it goes blank screen i cant acces boot menu by pressing f12 i cant access bios setup menu by f2 when i press these it only show entering...
I would contact www.toshiba.com amd speak to the technical department, they are very helpfull. It may be a RAM fault or a hard drive fault but as you have data on the drive, I don't want it to go pear shaped and for you to lose any data.
Hope that helps.
Mar 09, 2011 | Toshiba Portege M800 Notebook
Toshiba satellite m35x-s114 boots to the toshiba screen then doesn't do anything else. Even with the f2 or f12 option nothing happens. I hear the fan (I think it is the fan) then no sound at all. I have to...
Try getting to the bios screen, if you can get to the bios screen then I would imagine the hard drive has failed. If it is hanging up at the toshiba splash screen and not allowing BIOS access, then I would lean toward a motherboard failure. Are you attempting a boot from the windows disc?, is that why you are trying F12? I have seen my share of these Toshiba M35's just give the Toshiba splash screen when there has been a motherboard issue. Changing out the main board will fix this particular problem. I had not found another solution for it.
Nov 27, 2009 | Toshiba Satellite M35X-S114 Notebook
Dear, I have a Toschiba lcd-TV 42X3000PG. In the power-supply(V28A00036500) their are 2 diodes in short circuit and the main fuse is broken. The 2 diodes are marked with "GA78" ,but i can't find them in...
If it is in Bridge rectifire then replace with 1N4002 Diode and it available in the market.. If in auxilary section better use BA159 ... Replace the fuse with same Amps..
Jul 10, 2009 | Toshiba 50H81 50" Rear Projection...
About motherboard
I believe you have overheating problem
Remove side of case and clean all fans including power supply one then clean and remove all fluff and dirt from Heat sink vanes.
Then vacuum out case include all vent holes and behind power supply ones
Then restart computer
Oct 10, 2008 | Intel D865PERL Motherboard
Entering the bios
There is 2 way to enter, you can use Toshiba HW setup for BIOS setting from windows. Alternately you can hit ESC several times after turn on the computer and hit F1
Good Luck
Jun 18, 2008 | Toshiba Satellite A15-S127 Notebook
Toshiba Tecra A2 Notebook Logo
26 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
