Question about Frigidaire AEQ6000ES Electric Dryer
After a few minutes my dryer says ad and a 3 lights are lit
Dryer will run but will not heat and the lights all flash
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# GLEQ2152ES, will run for a few minutes and then stop and display "AD" with the lights flashing. The "AD" means that your appliance was in an automatic dry mode. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire GLEQ2152ES Electric Dryer
My frigidaire dryer GLEQ2152ES0 runs but no heat ?
Good Morning Friend,
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# GLEQ2152ES0. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Dryers
Bosch classixx tumble drier lights flash
The lights are flashing as an error code? what lights are lit/flashing, what rate of flashing etc? more information may help sort this faster
Mar 24, 2014 | Dryers
Stops and all the lights come on
Instructions
    • 1 Make sure the home's gas supply valve is turned on. Check your Maytag owner's manual to find the location of the dryer's gas shut-off valve. This is usually behind the dryer's front panel or in the back of the unit. Open the valve to allow gas to flow into the dryer.
    • 2 Open the lower front panel of the dryer to access the pilot light assembly. Press and hold the starter button as you light the pilot with a handheld lighter. If you have trouble getting it to light, release the starter button and wait a few minutes before trying it again. Once the pilot is lit, hold the starter button down for another minute to make sure it will stay burning.
    • 3 Close the dryer's front panel and run a test cycle to see if it is producing heat. Call a repairman to evaluate the problem if lighting the pilot did not restore the heat.
Jan 15, 2013 | Kenmore Dryers
Won't start. Light are lit, but the 'start' button does nothing.
If the display shows an '88' then place a heating pad over the display. In a few minutes the '88' code will clear, and the dryer will work. Sounds crazy, but it works for me every time.
Oct 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool duet washer dryer, Dryer is stuck on control lock
look to the far right buttons labled control lock, hold it in for 3-5 secs, to unlock
Mar 23, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryer won/t work
Hello chuhunghuang
Welcome
You said, your control lock light is lit. dryer will not work
Let me know how it goes!
Try ,
Pressing STOP/CANCEL to clear the display.
If this does not work.
pull the plug for 5 minutes or if you can't reach the plug you can turn the power off form th breaker for 5 minutes.
This should reset the system.
Bless You huuum
Please leave a rating before you leave the site!
Oct 12, 2008 | Whirlpool GEW9250P Electric Dryer
Dryer runs but no heat
check the air flow sensor is at fault
Jul 01, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
27 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
