Question about Duraflame Electric Fireplace Stove DFS-750
Heater works sometimes duraflame electric dfs7506
Fan runs but wont heat sometime if you bounce it will heat for a while
2 Suggested Answers
  • 93 Answers
SOURCE: i have a duraflame electric heater that starts to smoke and nake poping noises when i plug it in is it malfunctioning or is it repairable
wow, unplug and look for a new one. The cracking and popping is usually signs of something cooking the wrong way inside. You might lok to see if something is inside that ought not be inside. A good inspection while it\'s unplugged is also good in checking what is actually broke. 9/10 times it\'s wiser and more cost efficient to just buy a new one. cut the cord off the old cord and properly dispose of it.
Posted on Dec 31, 2014
My flame quit working in my red core heater.
Amazon.com - Redcore S2 IR Stove Heater - Space Heaters
www.amazon.com/Redcore-S2...Heater/.../B008QJV9...
Amazon.com, Inc.
Rating: 3.7 - ‎29 reviews
Buy Used and Save: Buy a Used "Redcore S2 IR Stove Heater" and save 68% off ... The flame is very realistic - my son and his friend thought this heater was a real wood stove. .... Also, the door was broken off the hinges when we received it.
FAQs About PowerHeat - DURAFLAME ' TWINSTAR ...
www.twinstarhome.com/duraflame/pages/faqs/index.html
What is quartz infra-red heat? ... It seems that the thermostat on my PowerHeat is different from what I believe the actual room temperature to be. ... When the heater isnot running, PowerHeat periodically runs a temperature accuracy test.
Customer Reviews: RedCore Concept S-2 Infrared Stove ...
https://www.walmart.com/reviews/product/22070668
Walmart
Jan 10, 2016 | Heating & Cooling
Enerzen customer Service address ... website phone number anything. I can find a remote?
New Enerzen 2000 Sq Ft Infrared Quartz Electric ... - eBay
www.ebay.com > ... > Heating, Cooling & Air > Space Heaters
eBayNew Enerzen 2000 Sq Ft Infrared Quartz Electric Portable Watts Heater in Home & Garden, Home Improvement, Heating, Cooling ... Duraflame Colby 1000 Sq Ft 1500WInfrared Quartz Electric Portable Heater Cherry ..... (1) Owner's Manual ...
Enerzen pro heater manual - Fixya
Nov 29, 2015 | Heating & Cooling
Why does radiator fan work when air is on but not when heater is on?
Have you waited long enough?
Sometimes it can take 5 -10 minutes before it turns on while using heater.
Oct 22, 2015 | Toyota RAV4 Cars & Trucks
Why does it take a long time for heater to come on?
The heater works with the hot water of the car radiator, on colder days it takes the water sometime up to 15 minutes to get hot. The heater in the car does not use electric heating etc, the safest form of heating inside the car is done through a fan running over a water heated core.
Nov 19, 2014 | 2007 Infiniti G35 Sedan
Cadillac problems electric motor runs while parked
if its under the hood then it is your cooling fans
Dec 11, 2013 | 1998 Cadillac DeVille
MY DURAFLAME HEATER COMES ON BUT ONLY BLOWING OUT COLD AIR?
Sounds like something in the control module. I have 2. One bought used about a year old. Lasted about 3 months and something in the control module or panel died so would not light or power up. I hard wired the blower and Infrared bulbs to manual switches so I can manually turn on and off heat. Have separate switches so can leave the fan blowing after turning off the elements to allow them to cool. The other heater was bought new and laster about a year and a half. Then the thermostat reading worked and fan worked cycling as should but elements would not light. Did a factory reset holding power button while plugging in. That fixed it for a day then back to same. took back off and while trying to trouble shoot voltages on the power supply module the elements started working again. Not sure what the issue but seems to be a definite issue with short lived control modules. To date have not found a resource to buy new control boards or other replacement parts besides bulbs which with the fans seem to be the most durable part of the whole heater.
Feb 20, 2013 | Duraflame Heating & Cooling
Heat sometimes works in 2003 envoy
First I recommend checking that your coolant level is good. Please check this cold so you don't risk getting burned. I have seen too many heater complaints where the coolant level was simply too low to fill the heater core. Next, you should check if the heater control valve is operating. I don't have any GM experience, but heater valves are often the cause of intermittent heater operation in many cars. Good luck!
Dec 20, 2011 | 2003 GMC Envoy
The pole buiding 24 in hanging Dayton sometimes the blower comes on like after 5 minutes after everything else kicks in and sometimes like when its supposed to and sometimes not at all?? All the electric...
I'm not sure whether this is a gas unit or not. With many gas heaters, the blower comes on when the heat exchanger gets hot enough and goes off once the heat exchanger cools. Other things are happening before the blower goes on. The blower is normally controlled by a "fan control thermostat". This stat actuates the blower when the furnace is hot enough so that cold air is not being blown around and allows the blower to run until the furnace cools enough to get out the remaining heat after the flame shuts off but not so long to again allow cool air to blow around. If this fan control is malfunctioning, you will get erratic runs from the blower or the blower may not run at all or run long or continuously. The fan control is the first thing to check.
Gary
Jan 31, 2011 | Dayton Gas Furnace Heater
Heat is not getting warm...just blowing out cold air. also, blower fan will blow sometimes and sometimes not. any suggestions?
I would check to make sur the engine coolant is filled up to the required level. Sometimes if it is low it wont be enough to circulate through the heater core. As for the heater blower, thats a whole other issue. There is a resistor pack which may be the issue. If so it should work on high. Or maybe the blower motor has a bad spot on the armiture. That could cause an intermittant issue. Beyond that there could be some other electrical demon in there. But so long as you get the hot water circulating there should be some heat.
Dec 21, 2009 | 2002 Chrysler Town & Country
Duraflame Electric Fireplace Stove DFS-750 Logo
78 people viewed this question
Top Duraflame Home Experts
ray gallant
Oliasys
Level 1 Expert
Michael Harrier
Are you a Duraflame Home Expert? Answer questions, earn points and help others
