Replacing front transfer case seal on vdj79r landcruiser
3dmaster
  • 183 Answers
SOURCE: 4wd TD oil leak
ya...
1 more way is ther but takes time ,quit more.
try to weld front differential where oil is gonna leak & but do this when your all oil is out of differential case than it will happen baater so,
another way is 1 solution which is highly recommanded for this type of crack in differentials,which still i cant get that name but at branded service center they will do for your differentials case.
THNX
Posted on May 17, 2008
  • 3 Answers
SOURCE: rear transfer case seal leaking...how do i replace it myself?
Rear output shaft? you should only have one transfer case :) Ok so put the ebrake on. Put the truck in neutral. Matchmark the yoke to the tcase. remove the bolts that hold on the ujoint. This should drop the driveshaft from the tcase. Use an axle socket to remove the nut holding on the yoke. Tap the yoke off with a soft face mallet. pull out the felt ring. Using a seal puller remove the seal. tap in a new one very carefully. reinstall in reverse order. ensure you torque the nut to the required torque aling with the ujoint bolts.
Posted on Apr 15, 2009
  • 383 Answers
SOURCE: oil seal leaking on 1999 gmc half ton 4w/d on front of transfere case do i need special tools or can I drop drive line and replace seal
billbohman: Unless GMC has had some change I am not aware of and that has not been published in service manuals for the repair of these units, the procedures are the same as any seal replacement and require no special tool. There are some universal seal installation tools which I would venture the majority of techs don't have because they substitute other tools in their place most of the time. Most techs will have a special tool designed from removing seals. However, the seal can be removed without it.
Just use a little common sense when removing a seal. Don't damage the casing.
Good Luck.
Posted on May 10, 2009
  • 33 Answers
SOURCE: 1996 chevy blazer housing between transmission and
No. The out-put shaft on the tranny goes straight through and there are no seals except for the transfer case out-put shaft. There is only a gasket that seals the two cases.
Posted on Jul 28, 2009
bsdracing
  • 57 Answers
SOURCE: leaky front seal on tronsfer case
depending on if its is from the drive shaft or the main shaft either way you will have to do a bit of work if it is the driveshaft seal I believe you can remove shaft and change seal with case in truck but dont qoute me on that if not remove transfer case and at that point it is pretty much the same amount of work for the main or the driveshaft side. get yourself either a rented or borrowed tranny jack and drain fluid before removal make sure you have all little tubes and wires off before you try and wrestle it out have a friend around for saftey good luck be careful and hope this helps
Posted on Apr 30, 2010
Landcruiser hzj75 hubs in lock in 4wd but front wheels not driving
is the 4WD in the transfer case locked in to drive the front diff.
Dec 28, 2016 | Cars & Trucks
Trying to locate flasher can for indicators on a vdj79r landcruiser workmate 2010
It doesn't have one, the flasher is mimicked through the BCM (body control module)
Jul 16, 2016 | 2010 Toyota Land Cruiser
Bellhousing leak
did you just have the fluid replaced in the transfer case?? if the answer is no, the you may have a leak from the series of seals that are internal. you will have to have the transfer case removed and have the CVT seal replaced and other seals inside of the transfer case. lengthy repair and costly also. the transfer case has to be removed to replace the CVT side seal and while you are in there replace seals inside of the transfer case also. that what its sounds like to me. transfer case seal leak or the inside CVT seal leak. however if its leaking right from the bellhousing, it also could be the torque converter seal. this is when proper diagnosis comes to play. if its d converter seal, than the trans has to come out. have this one checked by someone that knows what they are doing. could be transfer case seal leak and it could be converter leak.
Jul 12, 2013 | 2003 Nissan Murano
Need to replace the transfer case seal
I will only guess
You most likely will have to remove the
transfer case, unless it is on the back
output shaft & you can get to it
You already knew that
You won't have to strip it clean,
if that is your question.
Just remove the yoke & whatever ,
to do the seal.
Apr 26, 2011 | 1994 Jeep Grand Cherokee
Replacing the front transfer case oil seal
don't stress about your springs just undo the shocks and sway bar and keep lifting the car you will unload the spring no tools needed...
Dec 30, 2009 | 2004 Toyota Land Cruiser
I have oil leak between transmition and transfer case
Separate the transfer case from the transmission and replace the seals at the rear of the tranny and the front of the transfer case.
Dec 05, 2009 | 1998 Jeep Grand Cherokee
Transmission fluid leaking back, 1988 Ford Bronco
your output seal on the tranny or input seal on your transfer case is bad. you have to pull your transfer case to tell. this is a pretty straight forward job. block wheels. put transfer case in neutral. drop front and rear drive lines.diconnect transfer case shift linkage. there is a short commponent connecting the trans to the transfer case. the bolt on either end face each other. remove the bolts to the transmission. the transfer case is heavier than it looks, i suggest getting help. pull back on the transfer case until it will drop down. it will pull out a bit because of the trans output shaft. replace what will probibly turn out to be the tranny output shaft seal and reassemble in reverse order.
Nov 06, 2009 | 1988 Ford Bronco II
What do i need to do to convert my c-6 4x4 tranny into a 4x2 tranny
get a 4x2 tranny, and replace the 4x4 tranny and 4x4 transfer case with it, you will also need to remove your front drive shaft, that operates your front FWD, and replace the drive shaft for the rear axel.....
Find a good Salvage yard and see about trading parts to convert to 4x2
Sep 14, 2009 | 1981 Ford Bronco
1996 chevy blazer housing between transmission and transfer case cracked are there seals on the rear of the transmission and front of the transfer case in the housing?
Jul 13, 2009 | 1996 Chevrolet Blazer
Oil seal leaking on 1999 gmc half ton 4w/d on front of transfere case do i need special tools or can I drop drive line and replace seal
Good Luck.
May 10, 2009 | GMC C1500 Cars & Trucks
Computers & Internet Logo
David Payne
David Payne
