Question about LG LMV1650ST Microwave Oven
Where is the LG microwave fuse located Model LMV1813ST ?
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Where is the fuse located on the LG Microwave # LMVM2075ST?
see the picture. and fix it. God bless you
Posted on Oct 02, 2012
How to remove LG microwave to check fuse? Model LMV1813ST Serial: 102TRXT01402
The service manual for your model is here. That and my video here will give you disassembly info.
More questions? Contact me directly here.*
* always include the full model number and FCC ID number from the label on / in your microwave
Jan 28, 2018 | LG Microwave Ovens
Lg microwave fuse location
Fuses are normally internal on Microwaves and opening the cabinet exposes dangerous voltages, even when disconnected.
The fuses used are 'Ceramic' and look like this.
ceramicfuse-3tkv02zfhnnile0ve5y4fcys-1-0.jpg However, just replacing it may not fix the problem, if you have a shorted component inside, it will need to be repaired by a competent shop/technician.
May 15, 2017 | LG Microwave Ovens
LG LMV1813 F4 error code
F4 means sensor open, You have to check the Humidity sensor.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 31, 2017 | LG LMV1813ST Microwave Oven
Replace thermal fuse for LG microwave LMV1813ST
If too much current passes through the microwave circuitry, the line fuse will blow. If the line fuse blows, the microwave won't start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. If you don't resolve the underlying issue, the new fuse will blow too. (Caution: The microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. Due to the potential for electric shock, it is extremely dangerous to replace the electronic components in a microwave. Only a licensed technician should replace the line fuse.)
Sep 28, 2015 | LG Over-the-Range Microwave
Microwave went totally dead while operating; there is power to the outlet.
If the control panel lights up intermittently, then you either have a loose connection somewhere near the panel, or a failing component on the circuit board itself.
Jul 10, 2015 | LG LMV1813ST Microwave Oven
Need mounting templet
http://kitchen.manualsonline.com/manuals/mfg/lg/lmv1813st_2.html
Aug 24, 2014 | LG Microwave Ovens
LG LMV1813ST MIRCOWAVE STOPPED WORKING?
The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
If the microwave is not working the thermal fuse may have blown.
When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Aug 02, 2014 | LG LMV1813ST Microwave Oven
LG Microwave won't turn off
Our LG did the same thing - called customer service and they told us the open and slam the door 10 times. It actually worked! It reset the switches somehow.
Apr 02, 2009 | LG LMV2053 Microwave Oven
LG LMV1650ST Microwave Oven Logo
348 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
