Question about Kitchen Ranges
Jenn-Air Gas Range Burners Won't Light
I have a Jenn-Air Gas Range Model No. SEG196 and none of the burners will light when I turn on the various burner switches.  I don't hear the usual "clicking" sound when I turn the switches to the "lite" position.  The range is about 15 years old.  This happened all of a sudden.  I can light all of the burners with a match.  Where do I start?
  • daretorepair Oct 28, 2007
    OK, so go figure.  I messed around with the flint attachment on the left side burners and basically undid and reasembled it.  Lo and behold it works,  This is very little insight I know and maybe someone else would like to profer why.
aborcass
  • 2651 Answers
SOURCE: jenn air range
1.black top nice and shiny, as far as streaks your gonna ahve to find a cleaner that works for you , i have a black cooktop and my wife uses clorox wiped to clean and then with paper towel wipes off and dries
2. as far as "saddle grill" calling the manufacture (number inside your manual) will be best source of info on that, of course unless you can find an aftermarket 3rd party maker
Posted on Mar 15, 2008
SOURCE: jenn air range, model CVG4280B,
I do not know the cause BUT the fan behavior (on for left burners, off for right burners) is by design. The high-speed fan has two switches; 1) the primary switch visible centered between top two knobs, 2) secondary switches integrated with left burner knobs.
Posted on Jul 13, 2008
  • 116 Answers
SOURCE: burner not working
Sometimes there is "leak" on the cable - the insulation breaks down some place else some the clicking sound is heard but no lighting. Look to see if the arching is at the electrode beside the burner - if it is then try cleaning the electrode and the areas around the burner so as to give better conduction to thr frame o the stove
Regards
Posted on Nov 16, 2008
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
  • 10865 Answers
SOURCE: viking range burners won't light
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
Posted on Apr 30, 2009
Jenn-Air Dual Fuel Range Model JDT8895BAS
The igniter will click on all the burners simultaneously no matter which burner knob is on. This is normal.
Aug 27, 2014 | Cooktops
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
Is there any kind of pilot light that I need to light? I just had the gas turned and none of the burners will light and the oven won't get hot.
There may be a gas shutoff on the range gas supply. If so,turn it on.
If it is already on,turn on a surface burner and use a match ti light it.
It will take several minutes for the air to purge from a system once gas supply has been restored.
Aug 03, 2011 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
Two burners on jenn air counter top make sparking sound but burners won't ignite
turn electricity off to ignitors. remove grates and clean up the burners good, they might have a clogged up hole. gas may not be coming out of burner holes. good-day !! if all else fails, just use a wooden match to light that burner.
Jul 11, 2011 | Microwave Ovens
JGC8536
If the front left also does not light normally, my best guess would be that the wires for the front left and right rear are crossed and the insulation may have fried. Besides that possibility, I have no clue.
Feb 14, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Jan 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Electronic igniters Model SEG196
there is a spark module that controls all four surface burners usually located behind the rear access panel. This may have been a casulty of the outage. good luck
Jul 16, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn air pro range 36" prg3610np
hi after the burner ignites turn knob until it stops trying to ignite thanks
Jan 07, 2008 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
Problem with Jenn Air Gas Range???
are you talking about the burners or the oven reply with model num and dont rate me till we are finished
Jan 02, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Kitchen Ranges Logo
481 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
