Question about Maytag Washing Machines
Maytag washer MAV8551AWW leaks water from water inlet after cycle is done.
My Maytag washer MAV8551AWW leaks water from the water inlet after cycle has finished. The tub was completely full and water was still dripping. I had to turn off the valves at the supply behind washer. Is the intermittent water control valve and the water inlet valve the same? How do I get to it and is it difficult to replace?
  • 76 Answers
SOURCE: Maytag washer PAV2300 water over flow
tidalwave If the water continues to flow even when the washer timer and the power to the washer are off then you are right and the water inlet valve has to be replaced. If it does it only when the washer is on then it could be different problems. In that case the first thing you have to check is the water level switch. This is the device which controls the water level. Remove the power first.Open the control panel and you will see the switch on the left side. There is the clear plastic hose connected to the switch. Make sure the hose is not loose. This is one of the most common cause of overflow. If it got loose, drain out all water from the washer before you reconnect the hose. If this is not the issue then you have to check the continuity across the water level switch therminals. When there is no water you should measure the continuity across therminals 11 and 12 (gray and orange wires). Whet the tub has filled up with water you should measure the continuity across therminals 11 and 14 (gray and light blue wires). If the continuity is wrong replace the water level switch. If you are going to do it, make sure there is no water in the tub before you will remove the clear plastic hose from the old switch. Good luck. Gendos. post back...
Posted on Jul 08, 2007
  • 177 Answers
SOURCE: Water leaking into tub from inlet
you need to replace the water valve. Look on line for parts for your model
Posted on May 13, 2008
  • 27 Answers
SOURCE: Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Posted on Mar 07, 2009
SOURCE: Leak
Your inlet water valve where the fill hoses attach is stuck open.
Posted on Mar 18, 2009
jackiaria
  • 350 Answers
SOURCE: Fisher and Paykel washer dripping water into tub.
Dear FixYa Customer,
First and Always go to the Manufacturer for Parts Compatibility and/or Service!
For a GREAT APPLIANCE PARTS WEB SITE click on the highlighted http:// link that follows...
Same-Day Shipping, Return Any Part
Save When You Do Repairs Yourself! @
http://www.partselect.com/Entry.aspx?
jackiaria
Posted on Mar 21, 2009
We were on vacation for about month and a half. Upon my return, I opened the front load washer (Maytag Front Loader Neptune Super Stack Mo. No. MLE20000AYW) and water came rushing out at me. The water...
Shut your water taps of at washer when you go away for long periods /you must have a small amount of water leaking pass water inlet valve of washer / You should have that replaced b/c that is the first sign that it may stick completely open at a later date/water valve is cheap compared to a flood...Hope I helped if I did please vote need more help please ask and good luck
Feb 05, 2011 | Maytag MLE2000 Front Load Stacked Washer /...
Maytag Atlantis MAV8551aww, loud grinding noise during spin cycle.
Yes. Junk It. Problems that cannot be fixed and customer service stinks
Oct 24, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Our washer fills with some water when not in use.
a faulty inlet water valve, the valveis not fullly closing causing water to trickle in, replacethe valve ( in the meantime turn off the water inbetween unsage)
Feb 23, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Washer transmission & brake bad - replace or not?
kenmore elite washer,but first if you want to try to fix it yourselt look on ebay,put make and model number and see what comes up,i got a new transmission for $70 took my time taking apart then reassemble and it was pretty easy,let me know how you do-mike
Oct 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Leaking when wash starts
If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • Oct 19, 2008 | Maytag MAH2400A Front Load Washer
    Maytag Neptune mah7500aww adding water to wash cycle problem
    Your inlet valve at behind top of machine is defective; or the pressure from your faucet is insufficient.
    Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
    Sites for spares:
    RepairClinic.com (which is good)
    espares.co.uk
    AppliancePartsPros.com
    Pl rate if helped.............
    Jun 06, 2008 | Maytag Neptune MAH7500WH Front Load Washer
    Leaking waher
    water can leak from the other valve while filling up if you dont have the hose on it,if you blank the valve off with a nut and tail with a coin and rubber washer in it that will fix your problem.hope this helps.
    Mar 09, 2008 | Maytag Neptune FAV6800AW Top Load Washer
    Washing Machines Logo
    41 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
