Question about Dehumidifiers
Dayton dehumidifier manual - Dehumidifiers
What is the P1 code on my Dayton Dehumidifier 5eaj9 mean?
Empty the bucket. Reseat the bucket carefully or the code will not reset. This is the only documented action for code P1.
Jun 14, 2014 | Dehumidifiers
How do I reset the dehumifier "set humidity" back to 35. It's on 90 now.
To reset the electronics of the dehumidifier, turn the OB/OFF Switch to OFF and unplug the unit for 10 minutes. After the time has elapsed, plug the unit in and turn the ON/OFF Switch to ON. During that time out, the electronics should have reset and reverted back to the original factory settings. From there you can set them as you like.
I hope this helped you & thanks for choosing FixYa.
Aug 22, 2011 | Dayton 1DGX6 Dehumidifier
Whar does the E1 code suggest I do?
E1 indicates that the filter needs to be removed and cleaned. Be sure to turn the unit OFF and plug it, before removing the filter. You can either vacuum the filter or if it's really dirty, wash it in warm water and dish washing liquid, rinse and thoroughly dry it, before reinstalling it. NEVER operate the dehumidifier without the filter installed. Doing so could cause damage to the unit.
Jul 04, 2011 | Dayton 1DGX4 Dehumidifier
Our maytag and dayton humidifiers all starts but no water collects in the bucket.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 02, 2011 | Maytag Dehumidifiers
Got a second-hand Dayton dehumidifier 5BB55 - does it need a filter?
All dehumidifiers need and have a filter, usually already installed in them. Yours may be located behind the front louvers of the unit. Remove the bucket and look just inside the bucket holder at the top, below the louvers. You should see a tab type handle. Pull that down and out. If it's dirty it can be vacuumed or if it's really dirty, wash it with warm water and mild dish washing liquid. Rinse thoroughly and allow to completely dry before reinstalling it. NEVER operate the unit without the filer in place. Doing so, can cause damage to the unit.
If you don't have one contact Grainger Industrial Supply 1-800-323-0620. As Dayton is a house brand of Grainger. You may want to see if an Owner's Manual is still available for your model. It will be invaluable to you in the future.
Hope this helped you. Please let me know. Thanks.
Jun 27, 2011 | Dayton 1DGX6 Dehumidifier
How to defrost a dehumidifier lost instruction
Simply turn it off and let it set! this will allow the coils to thaw.
Nov 27, 2010 | Dayton Dehumidifiers
The display reads "P1" and I can't change settings. Can't find what "P1" means in manual. Can you help?
just type in the type of air conditioner on line when you log on and ask the computer or view functions for the ac when you doas i stated about enterig it online.
Oct 07, 2010 | Dayton 1DGX6 Dehumidifier
The drain hose is not draining. I am manually having to empty the bin.
Hello my name is Heath it will be my pleasure to assit you. If the hose is plugged it will not drain disconnect the hose and use compressed air or a garden hose to flush the hose out with water.
Jun 16, 2010 | Dayton MDF65AE Dehumidifier
My Dayton Dehumidifier drains out the hole designed for a hose connection. How do I get it to drain into the container in the unit?
If you want to use the bucket to collect the water cover the hole in the back where the hose to dispense water outside would normally go. You need a rubber cover that will fit tightly, it should have come with the unit.
May 23, 2010 | Dayton 1DGX6 Dehumidifier
Dehumidifiers Logo
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
