Question about Philips (33-01-031) Headphones
Need a charger and batteries for philips sbchc8442/34
Where can i buy a charger and batteries for my philips headphones model no. sbchc8442/34?
The batery in my sennheiser headphone only last 3 minutes after charging.the chargin lightin the charger dont come on
Obviously your rechargeable battery isn't getting charged. It's probably a good battery as it recovers enough to run for 3 minutes after you try charging it. (all that's happening is the battery is allowed to rest and it recovers a little bit of it's capacity.)
As to why it's not getting charged, it could be the charger or the wiring in the headphones or the wiring in the base or a few other possibilities. You didn't give us a model number or any other details so we can't get any closer than that.
Nov 28, 2016 | Sennheiser Audio Players & Recorders
Help I have lost my charger for Philips SC2006/11 Lumea charger, model NL9206AD-4, where can I buy another adapter?
Suggest that you try to reach Philips support: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Apr 15, 2015 | Philips Televison & Video
Headphones Panasonic
if these are older headphones it's likely that the batteries have gone bad or are defective, if this is a new unit, (aside from returning it for working one) it could still be the batteries, but the other likely issue is the charging unit is defective. you could test with a volt meter to see if it's getting juice. you could also have a short in the headphones somewhere.
Dec 03, 2013 | Sennheiser RS 110 Consumer Headphones
My problem concerns my new Philips SBC HC8445 wireless headphones. After using them for some time, the sound starts to cut in and out. First I thought it was because batteries were running low, but after...
after NiCd batteries are recharged many times they develop a memory and will not maintain a charge past the time that they were again put on the charger. If this doesn't make sense, do this: buy new batteries and install them, and keep the old ones for spares
Mar 20, 2011 | Audio Players & Recorders
I'm looking where to buy sony mdr-rf970r ear pads
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=modelSearch&searchText=MDRRF970RK&sessionId=FLk3TTjKj9RC2AYaSnUQb_k
This is the link from sony style for accessories and online ordering for your headset. Hope this helps.
Oct 03, 2010 | Sony MDR-RF970RK Headphones
Changed batteries still not charging
I suspect the problem is with the charger itself.
Please cross check.
Hope this helped.
Jan 06, 2010 | Philips (33-01-031) Headphones
SONY MDRIF610 Wireless infrared headphones -- I have two sets that won't work -- the Infrared units light up, but I get nothing from the headphones, which haven't been used in a long time and don't seem to...
Hi, to reach the internal battery You have to 1) gently detach the L(left) internal soft ear cover from the headphones, 2) Unscrew the 4 internal screws -- To replace the original NiCd 600mAh battery, You have to unsolder the contacts of the old battery and solder the contacts of the new one. You must buy a battery with soldering tabs, because tabs are very hard to solder well. - Yes, ONLY with this model You may use a NiMh battery, because the original charge-circuit was designed to stop after the battery is fully charged. (NOT many NiCd battery chargers have a cut-off circuit based on battery charge. they use only thermic protection cut-off) -- I've used 2800mAh NiMh to solve the problem, but I'm thinking to use the new hybrid cells battery, because they have a very small discharge rate when are not in use. -- No, You must not use LiIon or LiPo because they need a more precise charging rate and they may explode.Simply don't do that! ;-)
cheers, Rcatech
Nov 21, 2009 | Sony MDR-NC11 Consumer Headphones
Philips (33-01-031) Headphones Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
