Question about JBL SP8C 2-Way, 8'' In-Ceiling Loudspeaker Speaker
Runing speaker wire
I am building a new home i want to run speaker wire before the drywall is installed
If your house will be inspected make sure the speaker wire has a seperate insulating jacket covering the 2 conductor wire. Make sure you use rough in brackets or measure exactly where the wires are located.good luck!
Posted on May 13, 2008
Get in wall speaker wire, type CL3. you'll also need to find out how big of a wire your speakers can use. Remember don't run along electric wires. Speaker wires should be kept away from such sources to keep the signal clean. Check local codes to make sure you are using the right wire. CL3 is usually okay anywhere in the US.
Posted on Dec 07, 2007
I would suggest that you run PVC tubes with speakerwire in them, that way you can change wire or add an extra wire later if you find the need.
Also this enables you to use cheap wires now and you won't have any problems if you like to upgrade later.
Posted on Nov 20, 2007
Use in wall speaker wire
Posted on Oct 29, 2007
88 vette aftermarket head unit stereo wireing diagram
Might be able to get an adaptor that plugs straight in painlessly.
Failing that it's the standard trace and identify method that eats time like crazy.
Apr 16, 2017 | Cars & Trucks
Want to add external speakers that are mounted in my ceiling. They are a good quality household speakers
How do I Connect Multiple Speakers to my HiFi Amplifier
geoffthegreygeek.com/connecting-multiple-speakers-to-amplifier/
Understand connecting multiple speakers to your hifi. ... In a home theatre amplifier with surround sound, there may be 5, 6, 9 or 11 amplifiers ..... Two 4 ohms speakers in parallel totals 2 ohms, not good for an amp designed for 4 ohms or more. .... I have 6mounted ceiling speakers and I want the same sound on all of them.
Home Audio Installation: Install a Whole-House Audio System
www.familyhandyman.com > Skills > Electrical
New high-tech components make it easier than ever to install your own ... what to buy and show you how to run the wires and mount the speakers and controls. The rest is simple plug-in hookups. ... Run wire and install speakers and distribution modules so that you can .... Put it right next to the audio equipment if you want.
In-wall and ceiling speakers buying guide - Crutchfield
www.crutchfield.com/.../home/speakers_inwall.h...
Crutchfield CorporationHome Speakers / ... In-wall and in-ceiling speakers have become some of our best-selling ... about audio quality, and are also a great solution for folks who don't want to... But instead of being attached to a cabinet, it's mounted in a frame and set ...They're a great way to add background music to small or awkward spaces, ...
Dec 28, 2015 | Audio Players & Recorders
Open Question I have installed a ceiling fan and have run the wires to a wall switch that also has only one black wire and one white wire. How do you wire to a double switch
Trust Me ...I am an electrician. There is no way (legally) to do what you want to do with the wiring that exists. One of two things can happen at this point...1) rewire the switch leg with 3 wire cable (Type NM-B aka Romex with 3 conductors + ground). This involves some skill and maybe some drywall repair. OR 2) buy a remote control for your ceiling fan. They sell them at most home improvement stores, and they install fairly easily in the motor housing of your ceiling fan. The transmitter runs off of batteries, and doesn't require special wiring to operate. Your wall switch will have to remain ON for you to operate, but the remote can handle the rest, like dimming your lights and fan speed control. Good luck!
Apr 22, 2015 | Electrical Supplies
1988 Gmc 1500 5.0 Runing bad
crankshaft position sensor ignition coil could just need a clean it might have a lot of carbon build up in the throttle body
Oct 15, 2012 | 1995 GMC Sierra C1500
I need to find out how to mount stereo MA-10D speakers to a wall. I can't see any mounting capabilities on the back, sides, top, or bottom of the speakers. Has anyone successfully mounted speakers like...
Hmmm. .U don't have option given for speakers to fix them onto the wall. You have to do the following steps.
Things U need are:
  • Masking Tape
  • Level
  • Pencil
  • Keyhole saw
  • UL Class 2 speaker wire
  • Fish tape
  1. Locate the studs closest to where you'd like to install your speaker. You'll want to install the speakers in between the studs.
  2. Tape the template that comes with the speakers in the center. Check to make sure your configuration is level and plumb. Your template will tell you exactly what size hole to drill to insert the speakers. Trace the opening you need to cut into the wall or ceiling
  3. Cut the hole using a keyhole saw or a drywall saw. Keep the section you cut open in case you can't install the speaker and need to patch the hole you just made. If the hole reveals plumbing, you need to relocate the speaker
  4. Run the speaker wire through the wall, or fish speaker wire from an existing installation.
  5. Install the brackets to support your speaker if one is included with your speakers. Some speakers use clips to secure them to the inside of the wall.
  6. Strip the protective coating from the end of the speaker wire, and insert it into the speaker jacks. Test your speakers now if the wires are attached to an audio source. If not, locate the other end of the speaker wire and hook it up. Testing now will save trouble if you run into problems.
  7. Surround the speaker with insulation to enhance the sound. Secure the speaker into place, and do any necessary patching or painting
Aug 27, 2010 | Roland MA-10D Main / Stereo Speaker
I have a ht-as720s surround system when i turn on the receiver the right speaker has static
check to make sure there are no electrical cords runing close by and or you conection to the speaker itself is good and what grade wire are ya using make your you using a good grade of wire if all else check to make sure that stactic is not comming from feedback on mostely due to other electronic signals which are emited when there are more than one set of components running together such as your reciever dvd tv
Oct 29, 2009 | Audio Players & Recorders
When i turn my radio on my sub makes sounds and backfeeds even when the engine is off. i tried switching the remote wire from my radio to different wires but it either doesn't work or still makes the...
Hi It will be an earth problem or even if your speaker wires or rca leads are running along side any power wires from your car, Find the most chunky metal part of your dash, clear all paint away, make the earth wire from your head unit less than 1 foot from you head unit and make sure its not conected to any earth that run back to your cars power system. if it still makes the noise make sure your speaker wires or rca leads are not running along the cars power wire they will pick up feed from them. make sure your head unit is not earthed to your cars arial silly as it sounds the arial plug in is one of your main earths to your cars audio system. hope you work it out
May 06, 2009 | Car Audio & Video
What is Class rated for the speaker wires?
NEC rating for speaker wire installation link : http://www.bluejeanscable.com/articles/inwallrating.htmI Interesting reading however that doesn't answer your question directly... You may have to speak with the local building/wring inspector if you are concerned about the rating. CL2 & CL3 are suitable for in wall use. If I were you, I would solicit the information from the place you purchased your wire.. they must have a direct line of communication with the supplier /manufacturer and should ba able to provide that information.
Sep 25, 2008 | Durabrand HT-3915 System
Blower won't stop runing.
First I would make sure that at the thermostat your fan is not in the on position rather than auto. Your other options are that your blower relay may be "stuck" or possibly the installer wired it improperly making it hot all the time.
Oct 25, 2007 | Heating & Cooling
JBL SP8C 2-Way, 8'' In-Ceiling Loudspeaker Speaker Logo
152 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
