Question about Ionic Pro TURBO Air Purifier
Solution to Cleaning Ionic Pro!
I have owned my ionic pro turbo max for just over 2 years and just recently started having issues with the "clean" light coming on after the cleaning process. After several attempts at cleaning the blades and making sure they were completely dry, I still got the "clean" light. Frustrating! I finally decided to give the ionizing wire more attention than just the slide bar. I simply used an alcohol pad and swiped the rod clean. Works like new! I thought the wire was off limits to touch but the company needs to place more emphasis on cleaning the ionizing wire.
SOURCE: Ionic Pro CA-500B Power On Instant Clean Light
If the plates are clean, there is nothing wrong with them. They are just 3 strips of metal... they don't even connect to each other unless they are in the unit. NO NEED TO REPLACE THEM.
Posted on Jul 28, 2008
SOURCE: ionic pro turbo
You need to clean all the stainless steel contact points inside the unit, not just the blades. Make sure you unplug the unit before doing this.
Posted on Sep 02, 2008
rdanner3
  • 3 Answers
SOURCE: ionic pro won't turn on
Solution, perhaps...
All electrical contacts can get a film on them. Try cleaning the contacts (at the bottom of the blade unit; you should see the three with the blades out) with an alcohol swab (make sure the contacts are dry before reassembly in this case) or a pencil eraser (vacuum the debris out before attempting to start it again).
If those contacts don't make up properly, the unit will think it needs cleaning, even though it doesn't.
Posted on Feb 23, 2009
  • 3 Answers
SOURCE: Ionic Pro makes weird buzzing noise
I found that the buzzing can be removed by blowing out the unit, cleaning the blades and taking a long cotton swab and alcohol to thoroughly clean the corona wire - carefully - don't break it. The wire should be clean enough that the slider/wiper runs smoothly up and down the wire after cleaning. If it drags or is rough to slide, you will still have noise no matter how many times you clean the blades. The wire gets a "crust" on it.
Posted on Sep 16, 2009
SOURCE: Ionic Pro clean light stays on after cleaning.
Yes.. press and hold on/off button for several seconds to reset the machine.
Posted on Mar 09, 2011
My Ionic Pro keeps making a static-y noise when turned on. What is causing it and how can I fix it?
Hi jackieelling,
I work for the Ionic Pro company. Make sure you are also cleaning the ionizing wire. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Feb 05, 2011 | Ionic Pro TURBO Air Purifier
Why does my ionic pro turn off for 2 seconds and demand to be cleaned even though it's been cleaned and dried and reset correctly?
I work for the Ionic Pro company. Please call customer service at 800-875-8577 and they will do some troubleshooting with you. Thank you, Mary
Dec 27, 2010 | Ionic Pro TURBO Air Purifier
My ionic pro turbo air purifier keeps buzzing even after I clean it
Hi lsalazar113
I work for the Ionic Pro company. Make sure you are cleaning the ionizing wire too. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Dec 19, 2010 | Ionic Pro TURBO Air Purifier
It buzzes loudly every 2 seconds
Hi johanm65,
I work for the Ionic Pro company. Please make sure you are cleaning the ionizing wire too. If that doesn't work, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Dec 10, 2010 | Ionic Pro TURBO Air Purifier
My Turbo Air Purifier shuts off on its own after about 1 minute when it's on high and about 10 minutes when it's on low. The blades are spot free and I have pulled the fiber cleaning rod up and down...
Hi jerry bauer,
I work for the Ionic Pro company. Please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Nov 28, 2010 | Ionic Pro TURBO Air Purifier
I have cleaned my ionic pro several times works for a few minutes and then says clean again what can I do?
Please call customer service for Ionic Pro at 800-875-8577. They will provide troubleshooting instructions and if they do not correct the issue, they will give you instructions on how to get your unit replaced. Thank you.
Feb 08, 2010 | Ionic Pro TURBO Air Purifier
I have a ionic pro turbo,when you plug it in it goes to clean
Trying calling customer service at 800-875-8577 and they will trouble shoot the unit for you and replace it if need be. Thank you.
Jan 22, 2010 | Ionic Pro TURBO Air Purifier
Ionic pro turbo
Mar 01, 2008 | Ionic Pro TURBO Air Purifier
Ionic Pro Turbo
When you turn on it goes to clean but unit has been cleaned.
Dec 25, 2007 | Ionic Pro TURBO Air Purifier
Excessive noise
Oct 26, 2007 | Ionic Pro TURBO Air Purifier
Ionic Pro TURBO Air Purifier Logo
64 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
