H7053-1802 private mode not allowed? - HP Hewlett Packard Laserjet Pro 200 M275nw Laser Multifunction Printer - Color - Plain Paper Print - Desktop. Topshot Laserjet Pro M275 Aio Clr P/c/s Usb 2.0 Enet Wl 600x600 Cl-mfp. Printer, Copier, Scanner - 17ppm Mono/4ppm Color Print - 600 X 600dpi P
That is what private mode means, the call will be private. You didn't list what model car you have or if this is a factory bluetooth unit ar aftermarket, so I can't provide any step by step instructions to get out of private mode.
The procedure to set private browsing can vary from browser to browser. Also, the term used for private browsing is different for different browsers. To know more about what term a browser uses for its private browsing mode as well as to know how to set private browsing, refer to the following section:
Monitor. This is usually a button which will temporarily put your radio in monitor mode. This turns off any private line (PL code) you may have filtering your frequency. This allows you to hear all users on your frequency, which are in range of your radio.
As evidenced by the lack of a numerical keyboard, your scanner is an oddball that does not allow direct keyboard programming of a known frequency. Rather, you can only transfer a displayed frequency from the SCAN mode or SEARCH mode into the PRIVATE bank. Details for doing this can be found on pages 24 through 26 of the Uniden owners manual. If you don't have the manual, you can download and print it, at no cost, here: http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit: www.RadioReference.com
You need to run it under windows 98 compatibility mode:
To do this locate the file "privateer.exe". By default, this file is located in Program Files/Global Star/Privateers Bounty - Age of Sail 2.
- Right click on the privateer.exe and select Properties. - Click the Compatibility tab. - Check the Compatibility Mode box by clicking in it. - Use the drop down menu to select Windows 98/ME. - Click Apply, and then click OK to close the window.
