Question about Bosch Refrigerators
Computer controil on kku 3201gb will not stay on
Top Notch Air Conditioner model AUS09H53F010L4 is not coming on and showing error code R8
Suction temp, sensor of compressor.
1. Check whether the resistance of sensor is normal, otherwise replace it.
2. Check whether the sensor wire is shorted out or if it open circuit,and whether the plug is well contacted, Whether there is welding off or rosin joint on the electric control board . Repair it if there is any above.
3. When the 1 and 2 are both normal, Then the components or integrated circuit is damaged, The controil board should be replaced.
May 07, 2014 | Heating & Cooling
Bosch kku fridge freezer
Has your compressor stopped working? The clicking sounds like a relay trying to start it but failing. Check the fan is working, and the condenser is clear and clean
Apr 28, 2014 | Bosch Refrigerators
My a/c went out...the repair guys have "fixed" it several times..I just came back from trip number 4 to have them say the a/c control head was needing to be replaced, what is it, is it hard to...
if you would be so kind as to explain what you are calling the control head then i would no doubt be able to help and advise but not sure what this american terminology means ,iam learning things like hood and pigs tails also dog kennels but iam thinking this means the controil switch on the dash possibly
Feb 25, 2011 | 2003 Kia Sedona
Ice maker not making ice
IF ice is in the cub slots and will not drop then the ice maker is at fault. If slots are dry fill with tap water and let freeze and if they drop and the water does not refill the tray then the dual water controil valve part=> WR57X10032 Dual Water Control Valve
Ice maker being electronic best to just get another if that's the problem=> WR30X10093
Sea Breeze
If you have questions please let me know, Thanks, Sea Breeze
Jan 25, 2011 | GE Adora DSS25KSTSS Stainless Steel Side...
I can't access facebook. It's being block by internet policy
If it is internet policy set by your job you might not want to fight it, but if it is your home pc, then go to the controil panel and Internet Options and lower your security level. Are you sure it may not be password protected too. But check the Security, Privace and Content advisor in Internet Options and reset them first then try again.
Aug 18, 2010 | Computers & Internet
My arctica side by side is running very cold...everything in frig is freezing, even when I turn up the temperature. The freezer, also, is running colder than zero. I've cleaned the back, coils, etc. and...
sounds like the controil board is locked in run
try unplugging it for about 10 minuts
if that does not work you will need service to properly dioagnos the control
the artica has had issues
hope this helps
Oct 13, 2009 | GE Profile Arctica 25.4 Cubic Feet...
The spin cycle is not functioning
electronical fault not motor but the controil unit is no working ok ....
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
When I turn my computer on there is a huge black box around my screen and the screen is really tiny. How do I get it back to fullscreen?
when you power up press F8 key then enter in enable vga mode.
Then go to controil panel and display property then settings.
Change screen resolution to 1024*768 then apply and ok.
You can also try last know good configuration.
Thanks for using fixya.
Please rate solution if it helps.
Jul 23, 2009 | Dell Inspiron 600M Notebook
Jaguar 2002 X-type - Engine dies - electrical problems
I have not got a jag yet, I am thinking about buying one I have owned bmws and audis. ALL CARS FROM europe have electircal probs. I dont know why, this prob sounds like a ground prob. I would check the controil mode on the firewall. Bmws always had a fuse there that would short out on the hood and cause the same prob. I just moved the fuse panel/controil down lower and never had the prob again. I know bmw are different but a car is a car.
Aug 23, 2008 | 2002 Jaguar X-Type
Refrigerators Logo
13 people viewed this question
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
