Question about Haier XQG50-11 Front Load Washer / Dryer
My machine is Aspira lid on top all open inside
Need an assembly instruction manual for an Office Depot Aspira computer desk, item #429-160
Purchase another identical desk from the same company.
Remove the instructions, photocopy them, and then put the instructions back into the new packaging, and return the second desk. Use the photocopied documents.
Jan 17, 2014 | Exercise & Fitness
Can not find the lid switch
Your lid switch should be visible, around one of the 4 sides of the lid. It will not be on the lid itself, it will be on the "top" of the machine.
You must open the top to get to the switch.
One kind of machine has a tiny white button at the back of the machine, right near the control panel.
To be sure, although I don't remember seeing one, it is even possible your switch is hooked to the hinge of the lid inside the top so you can not see it without raising the top.
Be blessed.
Apr 20, 2013 | Estate Washing Machines
I need to see the inside of a lid switch
a lid switch is a electrical compoent that is normally closed making the ciruit n becomes normally open when u open the lid . they come indifferent configurations n are used for many applications
Oct 19, 2012 | Kenmore 24032\24036 Top Load Washer
Lid will not open
It means your lid switch is defective.If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch this videos below.
http://www.repairclinic.com/Washing-Machine-Troubleshooting#repairHelpVideoTabs Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Thanks
Jun 27, 2011 | Washing Machines
The load finished on my whirlpool cabrio washer (topload) but the machine won't unlock the lid?
you need to replace the lid lock. the latch probably broke in 2, and the broken part is whats keeping the lid closed. if you have clothes inside you can open the top by using a putty knife to release the front clips holding the top of the machine down. push each clip in and lift up. you will also be able to access the lid lock this way.
May 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Kenmore 22712 Top load will agitate, but when it switches to the spin cycle I get nothing. The motor wont run and the tub doesn't spin.
open the lid a lttle and close it down a few times,if you don't hear a clicking sound when it closes you have a bad lid switch,or open the lid and stick a screw driver in the hole where the piece on the lid goes down into when the lid is closed, if it doesn't click and the machine doesn't run then the lid switch is bad.,they don't want the machine to run with the lid open when it goes into the spin cycle,if you send the full model number located beneath the lid when it's open on the back panel under the lid.let me know how you make out
Jan 13, 2011 | Kenmore Washing Machines
Once filled, my washer sits indefinately until I open and slam the lid down several times. Any ideas?
If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Nov 26, 2010 | Maytag Legacy Series Top Load Washer
Water is not draining out
sounds like the saftey switch located where the lid closes, you will find attached to the inside of the lid a pin or tab that when the lid closes allows the washing machine to turn on and turns off when the lid is opened, to test if the switch is not working, with the lid open take a pencile or pen and push down on the switch which is located just oppsite where the tab or pin on lid comes in contact with the machine
Nov 08, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Drum won't spin. Do you think it's a broken belt? The water DOES go out. Thanks, Nancy
hmmm... washing machines usually do not have belts. they have very expensive transmissions...
could be as easy as the lid switch thinking the top lid is open. they have an interlock so it will not spin with the lid open. The switches are on the inside so you have to take the top off to access it.
Peace
Feb 27, 2010 | Kenmore Washing Machines
Washer does not power on and is getting power at the outlet
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Open Questions:
See all Haier XQG50-11 Front Load Washer / Dryer Questions
Haier XQG50-11 Front Load Washer / Dryer Logo
24 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
