Question about Thermador PGR366 Gas Kitchen Range
Thermador PRSE486GDS has never worked correctly! No repairmen want to come near it. Oven runs as high or low as it wants, none of the cooktop burners ignite
  • 1314 Answers
SOURCE: Thermador oven/broiler turns off after 5-8 seconds
two things come to mind a faulty safty valve thats the device that the ignighters connect to the other maybe trash stopping the screen on the pressure regulater are any codes displayed on the clock
Posted on Jan 30, 2008
SOURCE: LP conversion for Thermador 4 burner range top
I have a Thermadore 6 burner gas cooktop PCG366E purchased January 08. I purchased the LP conversion kit, they only make one kit for all models. The instructions included with the kit were written for an older model and have not been updated by Thermador. The gas regulator is located next to gas inlet pipe. You have to get at it from above. Remove the 2 star burners over that side of the cooktop. You will need a 20mm socket to remove the nut at the center of the star burner. Lift it off and disconnect the wire to the ignitor ( You need to push on the spring lock in order to seperate the the connector terminal). Remove the stainless steel pan and then remove the metal pan underneath ( you will need a Torxs bit for this screw or vise grips). You should now see the regulator. At the top of the regulator is a cap with the letters NG visible. Twist this a 1/4 turn ccw, lift up and turn over to expose the letters LP reinsert. The regulator is now ready. You will need to replace the orifice tips at each burner. Use a 7mm socket with an extension. Put a piece of tape in the socket to hold the orifice in place while you insert it. You also need to adjust the valves. You must pull off the knobs and and remove the trim bezel. If you look through the screw hole on the right you will see a screw head (bypass screw). Insert long skinny flat blade screwdriver through the hole and turn the screw CW all the way (about 1/4 to 1/2 turn in my case). My cooktop had two burners with a low simmer feature, This devise is located in front of the bypass screw. It has a hole in it but does not align well with the head of the bypass screw and makes it difficult to turn the scew. Thats it, I hope this info has been helpful. I have not yet connected the propane therefore have not tested the unit but it should work.
Posted on Feb 27, 2008
SOURCE: oven shuts off
Sounds like the spark module has been shorted out and quite possibly the main control board. Apptech.
Posted on Oct 19, 2008
SOURCE: After running self cleaning cycle, oven won't heat.
I own a similar range. As you can imagine I was dismayed to find out that my $6000 heap can't run a clean cycle, unless of course you just don't want to use your oven again. let me give you a tip something WILL break on your oven every time you use the self cleaning "feature".
The first time I used the self cleaning feature the board burnt up, I asumed hat this was a fluke. The second time the pvertemp sensor burnt out. The next few times that I was brave enough to try it the overtemp sensor triggered this is what I hope has gone wrong with yours since while it's not easy or convenient to fix it is free. If you pull out your range and remove the backsplash and then the rear panel there should be a breaker with a button you can push to reset. On mine it is located near the top of the oven compartment on the left side near the middle. I hope that works for you and you will soon learn as I have after doing this a few times that the self cleaning cycle is just not worth it. It willdo this every time and it really is just easier to use easy off and clean the oven by hand. I realize that is not what you had in mind doing when you bought a luxury Item like a 36" thermador range, but I hope you don't have to hate yours as much as I hate mine.
Posted on Oct 28, 2008
SOURCE: Thermador RDSS30 Cooktop works fine. Oven will not
My Thermador CT 127 Convection Oven will not turn on. Lights work, convection fan works, oven will not heat.
Posted on Apr 14, 2010
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
Thermidor GG30 cooktop front large burner will not light, does not spark. Three other burners work fine. Need instructions how to disassemble and repair. I am handy but no experience with this item. ...
Here is the part to order.
Close the valve in the gas line connected to the Thermador oven. Unplug the cooktop's electrical cord from the wall outlet.
Remove the screws under the front edge of the Thermador cooktop below the cabinet to release the cooktop from the countertop.
Put on work gloves then raise the cooktop at an angle. Recruit a friend to hold up the appliance while you work on the igniter underneath. The igniter is a pronged strip of black metal in a housing wired with two plugs connected to powericon1.png sockets underneath the Thermador cooktop.
Disconnect the two wired plugs on the end of the igniter from the sockets.
Take out the two screws in the metal plate that hold the igniter in position under the Thermador cooktop. Pull the igniter out of the mounting bracket in the cooktop.
Hold the new igniter by the housing and insert the part into the mounting bracket. Secure it with the two screws.
Connecticon1.png the two wired plugs to the sockets. One plug is larger than the other, which makes it simple to connect them correctly.
Lower the Thermador cooktop into position on the countertop and reattach it with the screws through the underside of the front edge.
Plug inicon1.png the cooktop's power cord and open the valve in the gas line.
Feb 09, 2013 | Kitchen Ranges
One burner on gas cooktop fires up but goes tick, tick tick.
There may well be water in the burner. It will evaporate in a day or two. Then it will work fine again.
please mark this answer as a fixya
Mar 18, 2009 | Thermador SGS36GS Gas Cooktop
Thermador Cooktop psc486glzs low burners not working
hi my name is mark, i called thermador and the tech.is correct they have switched to 110v valves. thanks for your question.
Feb 18, 2009 | Thermador PSC486GLZS Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Gas range with stricker burners and oven burner
Most likely the oven will not work because the striker is not coming on. I am not very familiar with this stove but most thermador gas oven uses a electronic igniter. the switch controls both the igniter(striker) and safety solenoid so if neither the striker or solenoid is not powered up the switch may be the problem
Regards
Nov 07, 2008 | Thermador SGS36GS Gas Cooktop
Thermador Gas Cooktop Won't Stop Clicking : SGC304RS
theres a part in the cooktop called a spark modual. replace it. when i goes bad the problem your having is what it causes
Nov 29, 2007 | Cooktops
Thermador PGR366 Gas Kitchen Range Logo
52 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
