Question about Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel
Low water pressure in Alira Grohe kitchen faucet
We have low water pressure at kitchen faucet only. We have old pipes that can't be replaced. How do we fix this problem.
5 Suggested Answers
SOURCE: water pressure very low
Sounds like the cartridge needs to be cleaned or replaced. May be clogged or faulty. This requires turning off water under the sink and pretty much taking the faucet apart.
Posted on May 03, 2009
  • 50 Answers
SOURCE: grohe pull out kitchen faucet the inner tube ripped
go to the store you bought it and see if they carry parts. if not , try the internet under grohe.com.
Posted on Jun 11, 2009
  • 115 Answers
SOURCE: Low water flow and pressure
remove aerator and cart. and soak in limeaway over night
Posted on Jul 26, 2009
  • 44 Answers
SOURCE: Low hot water pressure on Grohe LadyLux.
1. If by replacing the flexible hose you mean the hose for the pull-out portion - you have more than likely kinked or bent the supply line to the hot (left) side of the faucet.
a) If this supply is braided, then simply shutting of the water supply, removing the braided line and either replacing or attempting to straighten it out will be your best bet.
b) If the supply is copper, you will have to cut the line cleanly and carefully. you will then most likely need a 1/4" or 3/8" compression/quickconnect BY 1/2" IP fitting to complete your repair.
2. Other possibilities include:
a) Failure inside the faucet body which will most likely be warrantied by Grohe if you push them hard enough.
b) A problem at your hot water tank, most likely the outlet side and *perhaps* you hadn't noticed the problem elsewhere.
c) The hot valve failing to reopen fully despite all appearances; applies if you turned off the water under the sink for your repair.
Posted on Aug 05, 2009
I have a single handle Grohe kitchen faucet with very low water pressure. All other areas of the home are fine.
Try this site
http://www.doityourself.com/forum/plumbing-piping/310875-low-water-pressure-new-kitchen-faucet.html#b
Also alot of videos on specific Grohe faucets on youtube. Not sure your model. Take a look.
Hope this helps some.
Jan 26, 2017 | Grohe Plumbing
Why is my grohe alira kitchen faucet loose
There is a nut up under the counter its hard to see but tighten that . Most faucets come with a special tool fo hat but can be done with wrench
Aug 31, 2014 | Grohe Alira Pull-Out Kitchen Faucet S....
Why is my grohe alira kitchen faucet loose on a granite counter
Probably a loose fixture nut under the counter behind the sink.
Yeah ya gotta pull out everything and crawl up into the cabinet on your back and see if the nut (right up at the granite, above the hot and cold inlet pipes) is loose. If it is THEN you'll need to tighten it. Wrench, slip-joint pliers or a basin wrench. (probably basin wrench which is a specialized tool made for reaching up into tight places)
Aug 05, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe pull out kitchen faucet the inner tube ripped
Jun 11, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
May 21, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Water pressure very low
May 03, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel Logo
181 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
