Question about Whirlpool WTW4820XQ Washer
When I pull out the clothes they are still soaked. I don't know how to get the top off so I can check to see if I have debris blocking the water from draining. The water does drain, and I don't see an
Serial #C10120286
SOURCE: Duet washer door locked
Pull the front panel off, look for a plastic piece , it has a filter that you need to pull out. turn it to the left pull it out and clean it. This solved the problem for me. had the same issues.
Posted on Apr 18, 2008
  • 1294 Answers
SOURCE: does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Posted on Mar 13, 2009
honeymokey
  • 3113 Answers
SOURCE: Whirlpool Ultimate Care II does not completely drain.
Mine will do this if clothes are left in it for a long period of time. The pump will not drain all water out because the will dry out the seals if they do. Your wet clothes dripped in the tub raising the water level to the bottom of the drum and that is why you have wet clothes. Remove clothes as soon as they are done, use cycle signal to avoid this.
Posted on Apr 14, 2009
shinn8
  • 85 Answers
SOURCE: washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
Posted on May 18, 2009
  • 111 Answers
SOURCE: My Whirlpool Duet clothes washer will work for the
F20
NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED. The pressure switch is not tripped after 6 minutes. Possible Causes/Procedure If there is no water in the unit: – Make sure that both valves at the water source(s) are turned on all the way. – Check for plugged or kinked inlet hoses or plugged screens in the inlet valves. – Verify inlet valve operation. If there is water in the unit: – Verify drain pump operation. – Verify that the pressure switch hose is in good condition and properly connected to tub and pressure switch. 1. Verify there is not a siphon problem. 2. Press PAUSE/CANCEL twice to clear the display. The machine will drain for 3 minutes before unlocking the door. 3. Unplug washer or disconnect power. 4. Verify wire harness connections to inlet valves, pressure switch, drain pump and Central Control Unit (CCU). 5. Check all hoses for possible leaks. 6. Plug in washer or reconnect power 7. Verify pressure switch operation. 8. Verify CCU operation by running a Diagnostic Test or any cycle.
Posted on Jun 26, 2009
How can I soak clothes overnight?
1. Open the door to force a soak.
2. Unplug the unit if you're able.
3. Shut off the circuit breaker.
Sep 02, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Maytag bravos washer will not complete cycles
Remove clothes from drum. Siphon out (or wet vac out) visible water in the drum. Blow into drain hose. This back flushes the system. After hearing gurgling and seeing bubbles come up thru the drum, you know its a fairly clear line. Now take your wet vac and siphon out remaining water by connecting it to the drain line using duct tape. The lights will correct themselves and your washer will now work normally. At least this is how I fixed mine without disconnecting anything or making a big mess. Good luck.
Apr 17, 2012 | Maytag Bravos MTW6600T Top Load Washer
Sometimes the top load clothes washer will not spin very fast and not all the water will com out. This leaves the clothes still soaking wet. What causes this???
over loading too often, belt slipping from ware needs replaced. could have kinked drain hose or debri in pump could make it take too long to drain and stops before it has a chance to spin
Dec 21, 2009 | Magic Chef Dryers
Wd865 spinning problems
PUMP IS BLOCKED OR PIPE LEADING TO IT ROMOVE FRONT BOTTOM PANEL AND YOU SHOULD SEE A ROUND THING WITH A SCREW IN IT REMOVE SCREW TWIST AND PULL OUT REMOVE DEBRIS AND TRY AGAIN IF THIS DONT WORK LAY MACHINE ON ITS BACK REMOVE PIPE FROM PUMP AND CHECK IT NOT BLOCKED WITH ANYTHING ITS QUITE AN EASY JOB TO DO
Mar 04, 2009 | Hotpoint Ultima WF865 Front Load Washer
The washer doesn't spin out the water. Clothes come out soaked?
if it washes ,,check your lid switch,,if it doesnt wash and spin check your motor coupling...onthejob
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
SPIN
Refer to manual; your filter could be blocked, or something could be clogged in the drain pipes. Plug off the wall & check the pipes, filter first.
Jun 06, 2008 | Kenmore Oasis HE 27062 Top Load Washer
When spinning the water is not going out when the cycle is done the clothes are soaked
Disconnect power
Check that the filter is not clogged,
open the bottom panel ( 3 screws on bottom front lip)
next open the large screw-on filter in center.
it will dump water. so have pans, towels,newspaper
Remove any debris and see that the pump impellers move freely.
Reassemble and try again. panel must be replaced as it has a safety switch.
Nov 17, 2007 | Maytag MAH8700A Front Load Washer
You water is not being pumped out when the spin is on; this is due to the outlet filter being blocked. Find out where this is from your users'manual and clean it out. This is to be done periodically according to your usage.
Jun 18, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool WTW4820XQ Washer Logo
18 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
