Question about Bosch 24 in. SHU53 Built-in Dishwasher
How do I run test mode for bosch she4am16uc dishwasher
  • 641 Answers
SOURCE: bosch dishwasher digital readout
It sound that the problem is cause the water level switch.The switch level is a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. Good luck !
Posted on Aug 14, 2007
rylee_smith
  • 8619 Answers
SOURCE: New SHE4AM16UC, professionally installed eight
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes). You should now be able to run the dishwasher as normal. If the issue returns, you could have a problem with the heating circuit (i.e. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 05, 2010
  • 414 Answers
SOURCE: How do I run Test mode for a Bosch SHU5302UC
Don't hold me to this but I believe to reset during a cycle you press simultaneously the two buttons with a dot under them (2nd in from the left and 2nd in from the right) 0.01 or 0.00 comes on the screen and the pump will run. To run a test cycle turn machine of, press and hold the same two buttons and turn machine on whilst holding them in, the machine code should show in the display (usually a number in it's 20's), release these two button and then immediately press them again, this should initiate the test cycle. The d/w should now run thru a test cycle. If no fault is detected the display will show 0 or 1. If anything else, please repost and I will try to let you know what the fault code represents. test sequence is usually is as follows.
Pump, fill, circulation motor, dispenser (listen for it to open), heat to 65 degrees, regeneration flush, intermittent pump, sensor recalibration (if the d/w has any), alternate fill/pump, pump, finish. Take approx 10-15mins to complete.
Hope this helps, pls feedback or reply if unknown code appears.
Posted on Jul 12, 2010
lancaster5
  • 245 Answers
SOURCE: Everything connected correctly but unit
Check your breaker.
Posted on Aug 19, 2010
SOURCE: Bosch SHE4am16UC dishwasher with possible
Hi, if you even suspect that this unit has been spiked, then please follow my professional advice and PLEASE get it looked at by a professional, i say this as spike damage can and is very very difficult to diagnose and further, repairs to the damage actually done, and also any potential stressed/damaged components too, these must be diagnosed and repaired first, or otherwise even if the unit is repaired, without doing so, well, it will simply fail again as the components that were stressed from the spike but not yet failed do so, in due course, after the unit is put back into service. Most often it's the main CCU, and or the microprocessor that are spike damaged among other things... Most often complete board replacement is called for just to be safe and sure.
Simply contact the manufactures local or head office, then ask them for a referral to an authorised service center, now make contact here and then when in face to face contact, if worried about costings then ONLY first ask just for the "Quote' this then will appraise you of potential costings and you can then go from there as to repair or possibly replace?
Even if one wanted to DIY, one would first have to obtain a service manual, to allow one to follow the troubleshooting procedures and also to glean those all important parts numbers to order spares that will be be needed, .and i have searched the 'net but have been unable to locate any?
Posted on Aug 30, 2011
How do i run a test / diagnostic mode for the bosch sge63e05uc (evolution series) dishwasher?
Are the instructions on how to run the diagnostic test listed in the manual? FYI, I couldn't run the test on my Bosch DW because it was just too broken. Over the years the dishwasher essentially fried its own circuit board with excessive heat, which I learned is a problem common to Bosch DW's. Bosch told me the lifespan of my model was 10 years; mine was 11 years old (but was repaired once or twice). I replaced it with a Miele; no problems yet after 4 1/2 months.
May 22, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
Soap dispenser will not allways open during washing
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Dec 28, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
No water getting into dish washer
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Nov 04, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
New SHE4AM16UC, professionally installed eight months ago. Worked fine with very light usage until now. Dishwasher starts normally but stops and signals "clean" after less than five minutes on any cycle....
Hi
-high temp wash
-heated dry
-high temp wash
-heated dry
Thanks
Rylee
Feb 05, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Bosch she4am16uc/01 not filling with water, can hear what I think is teh pump starting then it just sits there. Autoclean light just flashes and I cannot reset the dishwahser... any recommendations?
pull the dishwasher out and look inside the pan you more than likley have a leak and this is why it is not filling it has a safety so when it leak it will not fill with any more water.
Dec 27, 2009 | Dishwashers
Bosch 24 in. SHU53 Built-in Dishwasher Logo
165 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
